tip discoloration?
tip discoloration?
I just added resonated test pipes to my header/true dual system along with the TS reflash. Now I notice the tips turning a significant gold/brown color with the insides being overly black. Should I be concerned about how my A/F has been set? The ECU has to go back to TS anyways since my idle went form the stock 600rpms to 200 rpms and idles like a truck. I hadn't mentioned the discoloration to the tech at TS, I'm not sure he could diagnose it over the phone.
Potential nightmare - rear bumper turns the same ugly brown we've all seen on the civics with the coffee can exhaust.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
TS is basically GUESSING when they play with your ECU. There have been 100's of posts on my 350z about people sending the ECU in 2, 4, 6 times and never having TS get the flash correct.
Doug at Crawfordzcar, sent his ECU in EIGHT times to get the "Crawford flash" the way he wanted it.
For this reason I'm going with the Apexi SAFC-II in the next few weeks (along with some tuning time on the dyno)... right after the Crawford Headers go on.
To Neffster: what does it mean by getting the flash correct? Running too rich or too lean? Or problem with idle and shifting timing? i dont get it....
I was about the send them my ECU, but if they cant get it right the first time! then might as well save myslef some time and money. It is a pain to get that thing out and send it as you know...
My next step may be the same. Finish the fine tuning at a shop with the Apexi unit and maximize the initial flash. At least I'll be able to see the changes and tweek it myself.
If the Apexi unit fits I've got a sweet little spot in the above glove box compartment mounted up next to the Escort g-timer.
. He sent it in a second time and here's the dyno chart (see below). Again, he had to pay for dyno time and had vehicle down time
. He is going to have to send it in a third time to get more fuel added...
Just do a search on my350z.com and unless you live within driving distance from Techno Square, I DO NOT RECOMMEND THIS REFLASH!
Sorry, I should have read further into the post...
BTW, there are plenty of posts where the pre-2004 ECU's have had the SAME problems. You could probably find posts here on g35driver.com, but you'll find many more on my350z.com that have had MAJOR PROBLEMS due to this "ECU tuning technique".
Trust me after 4 reflashes and a A/F of 14-14.5 Technosquare still has not worked out all of the bugs for the 04 reflash. My car is very modded and stocks g35's dynoed higher than mine after this so called reflash from then. The only thing I get now from them is excuses. What a big waste of $600......
Screaminz
Screaminz
Anybody know if there's any truth to the SAFC units adjustments being negated by the ECU's learning ability? Doesn't seem possible given the unit overrides the A/F % values determined by the ECU.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
