exhaust experst input only !!!
there has been great debate over this in 3 other forums.
what are the pro's and cons of true dual, many say no diffrence some say big diffrence.
pro's
1. better air flow
2. better look
con's
1. heavier
2. cost more.
your input in greatly appreciated.
pro's
1. better air flow
2. better look
con's
1. heavier
2. cost more.
Maybe you should go and find an exhaust experts forum if you only want their opinion.
Well one might assume that Nissan employes "exhaust experst"
and that they might know a thing or two about designing an exhaust system.
For some reason they chose to have a certain diameter y-pipe and not a true dual exhaust. Back pressure is an important consideration with exhaust design, and we all know that for Turbo applications, true dual exhausts rule. Many people have had TD exhausts with S/C set ups and several of them switched to the Y-Pipe set up and said that the cars "responded better" to the y-pipe design. Esemes, a Florida Local immediately comes to mind.
Also demonteverde321 (another FL local) installed Esemes' old BORLA exhaust on his coupe. He did pre and post dynos and gained a whoppin' 2rwhp at redline.
IMO a NA or S/C'd G35 benefits as well if not better with a y-pipe.
and that they might know a thing or two about designing an exhaust system.For some reason they chose to have a certain diameter y-pipe and not a true dual exhaust. Back pressure is an important consideration with exhaust design, and we all know that for Turbo applications, true dual exhausts rule. Many people have had TD exhausts with S/C set ups and several of them switched to the Y-Pipe set up and said that the cars "responded better" to the y-pipe design. Esemes, a Florida Local immediately comes to mind.
thanks todd, i have a coupe for people who dont know, and what i meant was my car is not true dual,which means it does not have dual piping engine back, stillen, borla offer that, and they way much more than stock considering alot more metal.
Originally Posted by roneski
Maybe you should go and find an exhaust experts forum if you only want their opinion.funny, u know what i mean i dont want a newb to come here and tryt o explain to me some bs
Cbohannan101
Sep 12, 2015 10:32 PM
