can't take the rasp!!!
Old Nov 6, 2015 | 09:24 PM
rpkinger's Avatar
Hey guys. Just had the exhaust done on my 08 g35xs. I now have top speed pro-1 resonated test pipes into 2.25 in. tubing. Replaced the y-pipe with custom x-pipe crossover leading back to magnaflow street series quad tipped mufflers. It sounds great when idling but when you step on it it's extremely loud and raspy. I hate the rasp more than anything. Sounds really ricy. Any suggestions on how I can eliminate the problem???? Thanks for any imput.
Old Nov 6, 2015 | 09:28 PM
Lartytiejdke3's Avatar
try going back to stock cats or at least HFC. that should alleviate the problem a bit.
Old Nov 6, 2015 | 09:54 PM
hurleyguys's Avatar
as jersey said take out the test pipes and replace with high flow or stock cats. the high flow cats will have some rasp but it wont be as bad. when i had high flow cats it was raspy at 3K RPM till about 3.5K RPM. otherwise sounds fine.
Old Nov 7, 2015 | 12:33 AM
rpkinger's Avatar
Thanks guys. I already sold the stock cats so i might try the hfcs. Also thought a magnaflow resonated x-pipe might help too instead of the straight x. Anyone have one installed? How does it sound?
Old Nov 7, 2015 | 12:35 AM
JOKER's Avatar
CLUB MODERATOR
Motordyne makes a resonated Y pipe.
Most of your rasp comes from your test pipes. Even though they are resonated.
I'm dealing with same issue. My setup is Fast intentions HIFLOW cats 2.5 to 3 inch Y pipe and Exotic speed exhaust.
I'm considering installing magnaflow 4 inch resonator (3inch inside) in the Y pipe to reduce the rasp.
Motordyne is doing it on their Y pipes, I'm willing to bet it will fix the rasp.
DavidMann1987
Dec 28, 2015 01:37 PM
mjfenix
Oct 23, 2015 12:27 PM
Ray Feta
Oct 14, 2015 04:03 PM
