03 G35 sedan removing 1 cat, O2 sensor?
Old Jan 27, 2016 | 07:06 PM
IAreBob's Avatar
Tomorrow, I will get my car back from the exhaust shop where they're removing one cat from my 03 G35 sedan. I wanted to know if I should remove the O2 sensor as well.
I may have read somewhere that the O2 sensor could cause decreased performance, or something along those lines, I don't know for sure, this is the first car I've modded.
Any info will help.
Old Jan 27, 2016 | 07:23 PM
hurleyguys's Avatar
i would hope that what ever pipe they replace your cat with it has an 02 bung.
and not to mention i would hope they take out both cats. cause otherwise you will have uneven exhaust flow and prob decreased performance from it.
Old Jan 27, 2016 | 07:47 PM
IAreBob's Avatar
What is an O2 bung and why would it need one?
Old Jan 27, 2016 | 08:08 PM
DeafBringer's Avatar
You might want to read up on this info before you take your car from the shop...
An O2 bung in the most simplistic terms is basically a nut welded to the exhaust with a hole drilled in the pipe and the O2 sensor threads into the nut.
These cars have TWO cats, not one.
Old Jan 27, 2016 | 08:14 PM
IAreBob's Avatar
I'll let them know to remove both, if they haven't already figured it out.
So I need to have the O2 sensors installed?
g35sweetness
Intake & Exhaust
Mar 30, 2012 01:14 PM
