02 sensors not ready code p0057
Old Feb 3, 2016 | 12:17 PM
jr-tito's Avatar
My g35 03 130k has failed the smog test. The code is p0057. I replaced both downstream with NTK. I also checked all wiring and fuses and they are fine. I was forced to go to 4 mechanic shops including the stealership. One mechanic told me i might need new catalyc converters but her is not sure it will fix the problem. The other said to contact the stealeship. The stealership said its an electrical problem and i might need a new ECM. Anyone has a similar problem? Ive spent too much trying to fix it and would like advice before i purchase and install an ECM.
Old Feb 12, 2016 | 08:53 PM
Phontain's Avatar
Do you have any modifications? Did you check voltage and resistance to the o2 sensor? Are your battery terminals fastened (you'd be surprised)?
Good troubleshoot guide is here http://www.obd-codes.com/p0057
Old Feb 12, 2016 | 09:04 PM
jr-tito's Avatar
I had my mechanic check the voltage. Is outputting lower than the others. The battery os good. Thanks for the website! It still hasn't fixed the problems.
Old Feb 15, 2016 | 10:47 AM
Phontain's Avatar
Is your car tuned? Sometimes the tuner will disable the o2 sensors if you're running test pipes.
Old Feb 15, 2016 | 12:33 PM
jr-tito's Avatar
Its can tuning i think the brand was cobb. I went to an infiniti specialist mechanic and he told me my ecu is wrong. I have an ecu for a sedan and i need one for coupe. The programming number goes:
After programing: 23710-am607
Before programing: 23710-am606
He was able to pass the smog test but did not fix my check engine light which i would like to fix. Im not sure what these mean so i would like to know if i need to buy a new ecu or if he can program the one i have.
edman911
Aug 19, 2016 05:42 AM
QX1
Drivetrain
Mar 18, 2016 03:01 PM
kethnguy
Northern California
Dec 29, 2015 03:14 PM
MarkeeG35
Engine - Exhaust
Dec 11, 2015 02:28 PM
stefelz
Dec 11, 2015 05:50 AM
