'05 curved throttle air intake hose duct boot - where to buy?
Old Sep 29, 2016 | 05:34 PM
mberd's Avatar
New member here. Need to replace throttle air intake curved throttle air intake hose duct boot (see picture). Turns out for '05 model it's sold only as part of air duct assembly for way over $100. Couldn't find after market part after online search. Any suggestions?
Thank you!
Attached Thumbnails '05 curved throttle air intake hose duct boot - where to buy?-img_3234.jpg
Old Sep 29, 2016 | 05:56 PM
bigc's Avatar
Wings Nation
I think that section of 'hose' connects to rigid plastic parts at both ends and doesn't have any vacuum ports coming off of it. If so, you can probably just replace that piece with a silicone coupler of the same length and diameter. A 15, 22, or 30 degree coupler would probably do the trick. The picture below is of 22 degree couplers on turbohoses.com (there are cheaper places to find these types of couplers):
EDIT: Cheap angled couplers --> http://www.ebay.com/sch/i.html?_odkw...egree&_sacat=0
Other options are picking up pieces of a used intake in our Marketplace section, or if you're open to going aftermarket, you could replace that section of 'hose' and the resonator with a z-tube.
Old Sep 29, 2016 | 08:44 PM
telcoman's Avatar
Veteran: Army
Thank you!
Why would choose an Infiniti that is a high end automobile with expensive replacement parts?
If you can't afford $100 + dollars for the intake hose you might be much happier with a Honda Civic that has much cheaper replacement parts.
Shop a few Infiniti dealers that have web sites. Using aftermarket parts on an Infiniti can sometimes give you more unexpected problems than you realize.
Just my $.02
Telcoman
Old Oct 6, 2016 | 05:22 AM
Blue Dream's Avatar
I drove ttrank's car solo
^^I doubt a hose coupler is going to cause "unexpected problems" lol. Man you give some good advice at times but I now often shake my head at a lot of your posts. If you think an 05 G is a "high end automobile" and a new owner should buy a $100 (or more) OEM intake tube for it you've lost your fvcking mind, no disrespect intended. That car is probably worth $5000 or less.
OP ignore his advice and get what you need to fix your ride where you want to. I second bigc's advice on the Z tube. He is the shizz and actually has a clue what he's talking about.
Old Apr 9, 2018 | 08:35 PM
kksG35's Avatar
Sorry to dig up this old thread...
I have the same issue on my 2006 sedan RWD. Shopping for silicone hose to replace this.
I rather keep the existing hose assembly and replace just this pita coupler...
Anyone know what are the dimensions and angle?
Much thanks in advance for any help with the dimensions.
Old Apr 9, 2018 | 09:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check the marketplace for anyone selling the stock intake, most folks replace that part with the Z-tube. I'd send you mine but I just inspected it and there's a little crack on that boot so you probably don't want it.
Old Apr 10, 2018 | 02:31 AM
victor0206's Avatar
I participated in that search before I found a cheap ztube on the 350z forums. Z1 has a set of couplers that replace both that top and the bottom one before the maf sensor. For about $40 if I recall correctly
Old Apr 10, 2018 | 02:48 AM
kksG35's Avatar
Much appreciate the thought and advice, thanks!
Old Apr 10, 2018 | 02:55 AM
kksG35's Avatar
Just saw the Z1’s today. I was replacing the coupler to filter box (Nissan OEM) when I noticed the throttle body coupler is cracked too... Grrr...
Else definitely the Z1’s is the way to go. But now that I already dropped $45 for the OEM filter box coupler... I hope to just get a silicone hose for the throttle body coupler from eBay for about $10.... Hence the ask for help on the dimensions... Sigh...
Old Apr 10, 2018 | 12:06 PM
cleric670's Avatar
BANNED!!!
Using my phone to measure the angle I get 25 degrees, 3" inner diameter, roughly 3.5" long nominal but it's hard to measure the length because it varies on the inside and outside angles.
Old Apr 11, 2018 | 11:38 PM
kksG35's Avatar
Thanks for trying! I tried also and having the same issues getting accurate measurements.
I went ahead and bought a 3 1/8” ID 45 degree silicone hose from eBay. Figure the hose is stretchy enough to fit...
Will update when I have it and attempted installation.
Old Apr 12, 2018 | 01:46 PM
cleric670's Avatar
BANNED!!!
If it doesn't work out I can send you my old one, I just inspected it more thoroughly and the rubber is cracked around the clamp but nothing is actually ripped through the entire thickness, it probably has a couple years of life left in it still.
Old Jun 21, 2018 | 05:22 PM
jbarnett250's Avatar
kks, did your hose fit? have a link for the one you got? i need both couplers. i have a stillen tube but it uses the oem couplers. wonder how long i've been sucking unfiltered air into my engine..... amazing how well it runs given how large an air leak these must be. The throttle body coupler is ripped about half way around the circumference just like the OP photo and two of the troughs in the accordion folds in the MAF coupler are cracked about 2 inches each.
Gigi_G35
Jan 30, 2017 08:59 AM
douglas555
Dec 11, 2016 11:51 PM
k_John7
Oct 13, 2016 02:12 PM
jerracus
Sep 30, 2016 09:37 AM
b_dupy
Sep 23, 2016 02:00 PM
