Custom exhaust suggestions
Old Mar 6, 2018 | 09:18 AM
AvidinG37's Avatar
Hello Folks,
(I apologize if this should be posted in G37 discussion instead)
I drive a '13 G37x sedan and recently removed the OEM mufflers as the first step in my process of building a custom exhaust. I had the exhaust shop cut off the stock piping up until the OEM resonators and welded on a larger 2.5” steel pipe that leads out to the exhaust tips.
The problem right now is that I’ve lost the low deep tone that I heard when it was just the muffler delete with no upsize in piping. The drone is so loud at 1500-3000rpm that it mutes the aggressive tones of the VQ. Not to mention the slight drone cruising at 75-80mph. My understanding is that the OEM resonators are designed for the smaller stock piping, and the upsize in piping has distorted the flow of air/pressure, causing the drone I am hearing. My goal is to eliminate as much drone as possible, while retaining a low deep tone in the exhaust.
My next step is to replace the OEM resonators with a pair of Vibrant ultra quiet resonators. However, as I read more and more about different custom exhaust set ups, I am beginning to wonder if I should perhaps replace the OEM resonators with chambered mufflers instead, or even keeping the OEM resonators all together, and just welding a pair of mufflers to the 2.5” piping. Will either of these alternatives provide me with the deep growl that I am looking for while removing the drone I am experiencing?
Would love to hear any input from exhaust enthusiasts or anybody that has gone a similar route with their G37.
Thank you
Old Mar 9, 2018 | 11:56 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Why not just add back some freer flowing mufflers? That would be the easiest solution.
waijai
Picture Share
141
Nov 6, 2011 11:06 PM
tgraing
Intake & Exhaust
Jan 1, 2011 06:10 PM
excluesiveonez
Sep 15, 2006 02:51 PM
