Next step in exhaust system??
Old Dec 29, 2018 | 07:54 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it does have anything to do with it then it's simply because of the average low rpm that an automatic transmission tries to maintain, you could achieve the same result with a manual by shifting early.
Old Dec 29, 2018 | 08:26 PM
cswlightning's Avatar
With a manual you can control it and drive around it. With an auto, you're stuck with it.
Old Dec 31, 2018 | 11:47 AM
herrschaft's Avatar
See, engine RPM is a much better answer since drone is dependent on frequency.
Old Dec 31, 2018 | 12:00 PM
Urbanengineer's Avatar
Call tony and ask, it's pretty awful man.
Old Dec 31, 2018 | 12:58 PM
gary c's Avatar
Stuck with it? Did you knowitalls forget those of us that run AT's also what the option of shifting manually...not that it matters? Sound frequency, depends on your exhaust system and amount of restriction! I've run 5 different exhaust systems since SLICK rolled off the showroom floor, two were sponsored and all worthless until I happened upon my HKS! If you recall they too had issues with the crossover restriction which was corrected with a 2.50" diameter x-pipe which blends the pulses from each bank. Rasp, I don't have no stinkin rasp! It is major fun passing a Prius pilot at speed just to wake 'em the hell up...Gary
Old Dec 31, 2018 | 01:41 PM
cleric670's Avatar
BANNED!!!
That's not at all what we're saying, the claim was made that a 5AT will have drone on the TDX2 exhaust system but the 6MT will not. Others disputed the claim and I suggested that it could be simply a matter of the difference in engine rpm (And then Herrschaft clarified that engine rpm changes frequency) since a 5AT will always try to keep the rpm low when driving normally, most folks don't drive around their 6MT in the 1200-1500rpm range though, not sure if the drone is present at city or highway speeds though.
The transmission itself doesn't generate drone, it doesn't affect the frequency emitted from the exhaust ports on the heads at any rpm throughout the engines range.
I'd be interested in hearing from folks with a drone issue on that exhaust system to see if simply using MM mode removed the drone due to operating at a different rpm.
Old Dec 31, 2018 | 02:04 PM
Yes, drone is from 1800-3000 RPM. Which makes so confused. Why not drone 3000-4000 RPM in your design?
And the drone is only under heavy load (Hills, slowly increasing speed, travel speeds interstate).
The way the AT applies engine power changes the drone too. Again. Call and ask tony. "THE DRONE IS NOT THERE IN 6MT MANUAL CARS."
No - changing to MM mode does not remove drone unless you drive 2800-4000 rpm all the time.
Old Dec 31, 2018 | 02:11 PM
cleric670's Avatar
BANNED!!!
Well I'm at a loss trying to understand why.
MAGIC!
It's literally the EXACT same exhaust system right? Same hanger locations, same everything right?
The only thing I can try to guess is there's some kind of harmonic dampening that happens from having a fluid-filled torque converter attached to the rear of the engine rather than a hard friction plate clutch.
Old Dec 31, 2018 | 02:14 PM
cleric670's Avatar
BANNED!!!
Like if you were to hit a large bell with a mallet, then have someone put their hand on the same bell while you hit it with the same mallet.
Old Jan 2, 2019 | 01:43 PM
By that thought wouldn't the bell be quieter? Haha. But yeah I wish I knew! Now all I wish for is to go back to OE!
Old Jan 2, 2019 | 03:12 PM
cleric670's Avatar
BANNED!!!
No I'm just saying it's a different frequency of sound, overall decibel level has little to do with cabin drone.
Old Jan 5, 2019 | 05:15 PM
Jeremy Parker's Avatar
Does a super charger effect exhaust sound? My car is at Crucial Performance now having one installed. May be a stupid question but I would imagine it does just not sure in what way.....I cant stand the sound of my exhaust now its annoyingly loud especially at lower rpm. Have high flow cats and a somewhat cheap aftermarket system behind it. What would you guys suggest for a good flowing muffler that doesn't sound so bad?
Old Jan 5, 2019 | 06:17 PM
You need a baffled exhaust chamber to quiet it down, or you probably should just upgrade.
Old Jan 6, 2019 | 03:24 AM
Demonteverde's Avatar
Moderator
I've been to Zdayz events and ZNationals events in the past and heard a few G35 coupes and 350z's with that exhaust that were in attendance. Without the silencers, its very loud and isn't subtle. The design was carried over and re purposed from Momentum Performance.
I personally like how the Motordyne and Fast Intentions Exhaust looks and sound for the G35 coupe.
Old Jan 6, 2019 | 06:47 PM
  #30
I just had great success having a local exhaust shop spend a couple hours welding $150 worth of Totalflow straight thru stainless mufflers onto my cheap aftermarket setup. Really killed the noise at low RPM.
