05 VQ wiring harness question
I am transplanting a G35 VQ and CD009 into a Nissan hardbody. I have a question about the engine harness.
the “end” of the harness has three connectors. Two are for the Downstream O2 sensors. The third one is a 3-pin connector that I can’t determine what it is for.
any help?
any help?
Crank sensor? I thought that was part of the transmission side of the harness though with the PNP switches.
EDIT: I'm pretty sure it's the crank sensor, those O2 downstream sensors pigtail to the harness that's at the very bottom of the transmission near the bellhousing and the crank sensor is right next to it.
Wire colors should be black/white stripe, brown, pink for the crank sensor.
