wiring harness?
Old Mar 1, 2006 | 06:36 PM
pfizzle's Avatar
wiring harness?
Is there a wiring harness for 03 coupes with bose? I just bought a pioneer deh-p80mp, I have the DD kit.. now i need a harness..
Old Mar 2, 2006 | 10:42 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Scosche NN03....
http://www.cardomain.com/item/SCONN03B
hope this helps...don't forget your Nissan Antenna Adapter too.
doc
Old Mar 10, 2006 | 09:45 AM
pfizzle's Avatar
I just got this in, and i went ahead and hooked up my pioneer wiring harness to the scosche nn03 harness but the wire harness on the G35 does not match up with the colors on the scosche harness.. is this normal?
I am under the impression that they would match up at color coded? any one have pictures?
Old Mar 10, 2006 | 10:41 AM
pfizzle's Avatar
anyone?
Old Mar 12, 2006 | 10:29 AM
docron1's Avatar
on the wiring harness package, there should have been a color coded guide. On your pioneer installation manual, there also should be a color coded guide. They may or may not be the same. I would just follow each wire and crimp them together....
e.g.
power wire from HU<---> power wire to harness
ground wire from HU <---> ground wire to harness
etc, etc etc
remember that you might have to individually run a 12G 12v wire from the back of your HU harness to your remote amp power terminal on your amp(s).
hope this helps.
doc
Old Mar 12, 2006 | 10:44 AM
GRider35c's Avatar
the colors match up with your new unit, not your G35...
Old Mar 12, 2006 | 02:01 PM
SDGuy's Avatar
Careful. If you have the remote bose amp and feed speaker level audio out of the Pioneer headunit (by connecting up the white, white-black, grey, grey-black, etc), you could blow your amp. If you do want to try it, just start with your volume set at minimum. See if you get any noise or distortion (very likely) out of your Bose system. If the sound is clear but just way too loud, you can try 1K ohm 1 watt resistors in series with all 8 audio leads (I've never tried this so do so at your own risk). What I believe you will need to do for the ultimate solution is to take the low level RCA phonos from your Pioneer and buy balanced converters to wire up to the balanced input pairs of the Scosche connector into your harness for clean audio. A good stereo shop might offer you some advice. Good luck. Howard
Old Mar 12, 2006 | 02:50 PM
Pearl05G's Avatar
Metra 70-7551 is for the Blose amp intergration.
You will need to supply your own ground, as its non existant in these cars.
Old Mar 12, 2006 | 04:47 PM
pfizzle's Avatar
I know that, I have a little knowledge on audio install. I did match up the colors from the pioneer harness to the scosche harness perfect, but then when I plug the scosche harness to the G35 harness the color is off.
Old Mar 12, 2006 | 05:47 PM
Pearl05G's Avatar
Off from what? The OEM colors are not going to match your Scosche harness. Ever.
Old Mar 12, 2006 | 10:00 PM
GRider35c's Avatar
that wont matter... as long as the harnesses fit, youre money!
Old Mar 13, 2006 | 02:28 PM
docron1's Avatar
I guess I didn't understand the question.....I'm lost.
doc
Old Mar 15, 2006 | 10:19 AM
pfizzle's Avatar
Audio Schematics
Anyone have the color schematics for the audio from an '03 coupe with bose?
Thanks
Old Jun 28, 2006 | 12:36 AM
n1cK's Avatar
G35 6MT
which antenna adapter is needed?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
