Correct ECM Pinouts for O2 sensors
Old Jul 29, 2021 | 05:28 AM
Scorpi0's Avatar
So I was recently tackling some O2 sensor codes because my vehicle registration was due and I had to get rid of the check engine light. In the process, I noticed the factory service manual actually has the wrong ECM harness pinouts for all the O2 sensor signal wires.
Per the FSM, the signal wire for Sensor2 Bank1 is pin#74. And Sensor2 Bank2 is pin #55. Here is a pic of the FSM:
And here are pics of the ECM harness from my car. You can see that there are no pins at spots 74 and 55.
I couldn’t believe they would make an error like this in the FSM.
So I grabbed my multimeter and started chasing wires to find the correct pinouts for all the O2 sensor signal wires. Here they are in case anyone needs them:
Bank1 Sensor1 (Passenger Front): Pin#73 =White wire
Bank1 Sensor2 (Passenger Rear): Pin#17 =Blue/black wire
Bank2 Sensor1 (Driver Front): Pin#19 =White wire
Bank2 Sensor2 (Driver Rear): Pin#36 =Red/yellow wire
My car is a 2005 coupe and I compared my FSM to that of the 03-04 and 06-07 and they all show the same pinouts, so I’m assuming those are wrong too. If any of you guys with an 03-04 or 06-07 ever get a chance to look at your ECM harness, please confirm if your pinouts are actually correct or not.
Old Jul 29, 2021 | 05:49 AM
Scorpi0's Avatar
Mods, I wasnt sure where to post this on the forum. Feel free to move it around if its in the wrong place.
Old Jul 30, 2021 | 05:10 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Wow, good info. This should be a sticky. I ran across an error like this a while back while trying to help someone here, except on a different connector. The ECU harness connector on my '04 coupe matches yours.
Old Jul 31, 2021 | 01:54 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wow that's weird, my 2006 rev-up has the correct pin layout.
Old Jul 31, 2021 | 04:29 AM
Scorpi0's Avatar
So your harness actually has pins at spots 74 and 55?
Old Jul 31, 2021 | 10:23 AM
cleric670's Avatar
BANNED!!!
I just felt behind it with my hand and the 4th and 8th slots on that row both have wires yeah. Didn't disconnect it or check colors or anything..
crystal80
Aug 7, 2019 03:41 PM
MannyFresh
Engine - Electrical
Apr 13, 2015 02:57 PM
Snuffaluphagus
Apr 24, 2012 12:08 AM
The Stimulation
Intake & Exhaust
Mar 5, 2012 03:21 PM
KevinE
Intake & Exhaust
Apr 19, 2011 05:52 PM
