Driverside o2 sensor wiring colors....HELP!
Old Oct 22, 2010 | 10:15 PM
KevinE's Avatar
Soooo.....my check engine light came on the other day. I had to change my oil...jacked the car up to see a dangling connector under my car and wires hanging from the o2 sensor dragging on the ground. Basically my car decided it didnt want the o2 sensor plugged in anymore....aka the connector was ripped in half and broken, the CEL i got was for the 02 sensor.
All i need to know is what wires go to what via the o2 sensor connector....there are 2 white wires, 1 grey, 1 black on the o2 sensor. There are 2 red wires, 1 brown, 1 black on the engine side of the connector. I will solder them together, i just have ZERO clue as to what wires go where. If anyone could point me in the right direction i will be extremely greatful!
Thank you!!!
-Kevin
Old Oct 27, 2010 | 12:43 AM
g35sweetness's Avatar
Old Dec 30, 2010 | 02:22 AM
G35-31's Avatar
I have same problem
Old Feb 21, 2011 | 10:12 PM
G35n300ZX_CURTY's Avatar
same problem cant find wiring schematic anywhere... ive put volt meter to everything got ohm readings everything writen down.. i feel like a 2 year old putting the circle through the square it fits just dont WORK and still cant just figure out if the heater wires need the constant 12v or what anyone out there got a diagram ... but i do know u do not want to solder the wires.. just crimp them something to do with what its made out of and how hot it gets
Old Apr 19, 2011 | 05:52 PM
KevinE's Avatar
Well i've been butt connecting these damn wires together....still am chasing the CEL regarding the sensor. Any luck with what wires go where anyone????
jwrape
Tuner & Dyno
Jul 14, 2011 05:06 PM
lmSteveO
Sep 18, 2007 11:23 PM
