Crawford Hi-Flo Cat's?
Old Apr 3, 2005 | 05:08 PM
Gordgee's Avatar
Administrator
Originally Posted by biscotti
Yeah, unfortunately its one of my O2 sensors, bank 2,which is the passenger side. Hopefully all will be well once this is replaced. Also had to bend the heat shield on the driver's side as this would rub against the frame when accelerating.
So you went in to see your guys? Hopefully that'll fix your problem. I'll give you a call next week to see what happened.
Also check out neff's post:
One important thing, does your friend have a car with a 10/03 build date or later? If so, he has an ECU that connects to a 6 wire O2 Sensor (instead of the 4 wire O2 sensor). The 10/03 model cars or later can't be run with straight pipes w/o throwing a CEL. I've read that stillen sells a ~$50 box to trick the ECU into not throwing the code, but if your buddie has a 10/03 build date or later this very well could be his problem.
Thanks for the feedback guys!
Old Apr 3, 2005 | 10:18 PM
biscotti's Avatar
Seems that there is only one OEM O2 sensor in all of Canada, mine should be arriving mid-week.
Crisci33
Jun 29, 2017 08:31 AM
magnetism80
Jan 27, 2016 12:57 PM
NJ6MT
Oct 9, 2015 05:02 PM
DRG35R
Sep 16, 2015 05:33 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
