CEL when replacing CATS...what have others done to fix
Old May 18, 2005 | 12:27 AM
G35Wizard's Avatar
I was curious to know what fix G owners have done when replacing their cats with free flows or test pipes. I am specifically talking about 04 models and up, as they seem to have these issues with the CEL. I just ordered my Crawfords and I have a 04.5 GCoupe and I know I'll throw a CEL. Will a Technosquare ECU tune take care of this? if not, what are my options besides 02 Simulators, which look to be my resolution. Thanks!!!
Old May 18, 2005 | 12:33 AM
eldy's Avatar
http://members.dslextreme.com/users/g35driver/o2fooler/
UPC #'s 3749542009 and 3749542002 from AutoZone or Pep Boys.
You have to bore out the set that the O2 sensors plug into to a diameter of 1/2" so that they will fit inside.
Worked for me, but I'm not giving any guarantees!
Old May 18, 2005 | 05:09 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
Seriously, what is up with these posts you are making?!
Old May 18, 2005 | 05:37 PM
jnkirk1974's Avatar
FYI guys. My post above was to a person who has probably had his message deleted by now. He was spamming us.
Thank you, drive through.......
Old May 18, 2005 | 06:03 PM
caelric's Avatar
Hmm, I have Crawfords (and other stuff, read my sig) and have not thrown a CEL. About the only thing I did do was when I had the front passenger seat out to put some dynamat on, I connected the battery to check the stereo wiring, and my airbag light came on. Easy fix, and nothing to do with the cats or the CEL...
Maybe you'll get lucky and not throw a CEL
Dave
Old May 18, 2005 | 11:45 PM
G35Wizard's Avatar
Hey Eldy, thanks man..that looks good!!! i should have them this coming up week and I'll give it a shot...thanks for those pics...ill keep everyone posted..
Old May 19, 2005 | 12:05 PM
jbone's Avatar
'04.5 Black 6MT Coupe
I have the Crawfords, absolutly no CEL issues. Great fit, just make sure they're installed properly, keep the MAF sensor clean
Old May 19, 2005 | 02:16 PM
SI_G35Coupe's Avatar
i have not had a CEL with either my old Kinetix high flows or my newer Crawfords... you should only get a CEL with test pipes
Old May 19, 2005 | 10:56 PM
Gman2004's Avatar
the cheapest and easiest way to fix the cel light....help method.
http://www.msprotege.com/forum/showthread.php?t=66426
I have these and they work. I even them installed them and I don't know chit about cars.
Old May 23, 2005 | 11:27 PM
G35Wizard's Avatar
Getting the cats tomorrow..but I had a quick question...if you drill out the inner part, how will the o2 sensor screw in?? the thing will be bald from drilling, right? Or, are you just drilling with 1/2" bit to make it a straight through design and the thread will still be on the o2 plug..
Old May 23, 2005 | 11:30 PM
Gman2004's Avatar
Don't know how to explain cause I am not mechanically inclined, but if I figurged out so can you. If you use the 1/2 inch drill bit it will not mess with the threads. There is something that looks like a washer in the middle. You need to drill that out. If you have a vice it will make life a whole easier.
Old May 24, 2005 | 07:56 PM
eldy's Avatar
The "wall" (1/4" hole) that you drill through is only roughly 1/8" thick. Once you get the parts you'll see that you're not touching the inner threads.
Old May 27, 2005 | 11:32 PM
G35Wizard's Avatar
nice...you're right, i got the parts and it makes sense..i feel like a jack@ss for even asking..anyways, My fujitsubo Legalis R FINALLY shipped and I should have it by Wednesday...ill get both the cats and exhaust installed together and I'll definitely post pics and vids..thanks guys!!
Old Jun 7, 2005 | 09:59 PM
G35Wizard's Avatar
installed test pipes and the fix and NO CEL so far..over 150miles...looking good...and OMG, the sound is ridiculous!! very loud and raspy from 2.5thru4.5 rpms....but definitely feel the car pull harder!!!
Old Jun 7, 2005 | 10:39 PM
RashMan1450's Avatar
So wat did you end up doing finally? You used that anti spark plug fuller?
