Megan Racing Y-Pipe any good? Saw this...
Old Sep 30, 2005 | 12:56 AM
Keith N's Avatar
Originally Posted by Mr_pharmD
well, i got mine in the mail today. The quality is okay but the inlet is around 2.3 and the outlet is around 3.1. Hopefully Ill see some hp gain with this, lol.
If you're still running the oem mid pipe, make sure that you have a muffler shop install an adapter for the flange size difference. Let us know the results.
Old Sep 30, 2005 | 10:31 AM
Mr_pharmD's Avatar
Really?? I thought this thing will bolt right to the stock mid pipe without cutting???
Old Sep 30, 2005 | 10:54 AM
Keith N's Avatar
Your aftermarket Y Pipe's rear flange is 3" in diameter and the oem mid pipe's flange is 2.5" in diameter. There is a reducer cone that will adjust to the difference for better flow. Here's a link - https://g35driver.com/forums/showthr...highlight=Pipe. Where are you located? In So. Calif.?
Old Sep 30, 2005 | 11:36 AM
Mr_pharmD's Avatar
I get wat you are saying now. I should get the Dr. Gas 3" to 2.5" reducer and weld it to my stock mid pipe instead of just bolting it right on. Thanks for the help and do you know where I can order one?
Also if our stock pipping is 2.5" and the borla is also 2.5", why is there gains over the stock exhaust? They are both the same diameter, so is the stock muffler the reason why we lose hp?
I live in Fresno, CA (central cali).
Old Sep 30, 2005 | 12:53 PM
jaspergtr's Avatar
Originally Posted by PieroG35
Very good point. That's why mine is for sale. I don't want to use a reducer on the B-pipe.
I think there would be a market for a y-pipe w/ a 2.5" outlet. Why arn't any companies making one?
kinetix made one, and so did jic. i had an issue with my kinetix y-pipe. wouldn't fit right. i think there is one more company that does it. can't remember what name.
Old Sep 30, 2005 | 12:55 PM
jaspergtr's Avatar
http://www.drgas.com/
call them. most likely they will know exactly what you want. they've done this before.
Old Sep 30, 2005 | 12:59 PM
jaspergtr's Avatar
there are a few reasons. but that compensation for loss of high end horsepower, is good torque down low. it's a give and take. but these exhaust systems aren't too bad. it's the other components, headers and cats, that could use improvement.
Old Sep 30, 2005 | 01:48 PM
Keith N's Avatar
Send a pm to Gsedan35 (Jim C). He's also in Central Calif. Jim is a great resource for information and advice on exhaust and suspension issues.
Old Sep 30, 2005 | 01:53 PM
Keith N's Avatar
I just installed my Tanabe Y Pipe. The pipe is very well designed, constructed and looks great. The flange to the mid pipe matched up really well. My butt dyno tells me that the car is building rpms much quicker with a slightly louder growl at 3500. I'm very happy with this mod.
Old Sep 30, 2005 | 10:02 PM
Mr_pharmD's Avatar
Hey Keith N, what kind of numbers are u putting down? I just saw your sig and I realized u have almost all the same mods I have for my g35 (just not installed yet).
As for mods:
Kinetix HF cats/plenium
injen intake
megan y pipe
alphawerks headers
ur crank pulley
gg 10 wire kit
6MT 350z rear differential 3.5 final drive with lsd (pumpkin)
Hopefully in the future, the ecu reflash and the stillen vb. I'm hoping to get this auto into the 13.5.
Old Sep 2, 2008 | 02:06 PM
bsowhat1's Avatar
Anyone running a Megan (or similar) Y pipe that has a 3" collector into a JDM exhaust that is 2.75" (70mm), like Tanabe or Apexi? I would think that the 76mm into 70mm transition would be horrible for flow and very turbulent.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
