Do you lose low-end torque with true dual exhaust?
Old Sep 24, 2005 | 03:43 PM
_G_'s Avatar
_G_
I have the HKS hi-power exhaust on order, but I'm a little concerned that I might lose some noticable low-end torque because of less back pressure. Is this true? I only have 1/2 plenum spacer and z-tube in the engine; other than that, it's all stock. I don't have plans for a turbo...yet. Maybe a S/C is in my future, but I really don't want to lose low-end powah!
Please chime in with your thoughts
Old Sep 24, 2005 | 04:03 PM
G35StrongMan's Avatar
I have the Invidia G200 and lost low end HP and TQ. I'm beginning to think a True Dual is too big for a NA car, unless you have cams and/or head work.
https://g35driver.com/forums/showthr...086#post738086
Old Sep 24, 2005 | 04:10 PM
PieroG35's Avatar
This is a good question. The larger diameter pipes provides less backpressure and velocity of the exhaust gases, this is true. So does any reduction in backpressure/velocity usually reduce low end power athough gaining high end power? This appears to be the case.
So if the above is true, would an aftermarket y-pipe (3" outlet) have the same effect although it may not be noticeable? Some low end sacraficed for high end power?
Danielek
May 1, 2022 01:28 PM
lamessi1018
Engine - Exhaust
Oct 20, 2015 04:24 AM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
G35CO
Sep 4, 2015 09:27 AM
erich2780
Sep 3, 2015 03:23 PM
