Please help, CALLING: Fujitsubo Exhaust Owners!! ERGENT
Old Sep 26, 2005 | 06:27 PM
VQ35sleeper's Avatar
Lenny
Please help Fujitsubo Exhaust Owners!! ERGENT
Hey, i was having a really hard time aligning the metal mounts on the muffler to the rubber mounts on the car. I ended up slightly bending the steel mounts on the muffler to better align with the rubber. I got the top two mounts in securly, but the last mount (the one which protrudes farthest back) just barely has its head in the rubber mount. Other then that the muffler is very secur-feeling. Also, when i started the car and drove a bit, i smelled a slight burning smell, very similar if not identical to the smell when you rev your engine high. I believe this is just because it is a new muffler, as i did not notice any gass leak. Please reassure me that this is OK, or give some advice as to how to fix it!
Thanks so much
Old Sep 26, 2005 | 07:55 PM
escobar929's Avatar
the smell is common, should go away w/ a week or two.
Old Sep 26, 2005 | 08:05 PM
Lenny
oh alright thanks man. What about that one mount? Its not one of the top two, those are securly in place. Its the one that is the longest, and kinda points to the front of the car. Its barely holding onto the rubber mount...
Old Sep 26, 2005 | 10:28 PM
sdkingka's Avatar
you might wanna post some pix of area you are having problems with. usually fuji has good fitting... yea the smell is very normal, and it goes away, and so does some sounds later on.
Old Sep 26, 2005 | 10:41 PM
codeflux's Avatar
sedan or coupe? your sig is useless in that regard.
Old Sep 26, 2005 | 10:46 PM
escobar929's Avatar
yeah pics would def help. the fuji usually fits like a glove, unless it was damaged during delivery
Old Sep 28, 2005 | 10:42 PM
Lenny
i have an 05 coupe. I figured that it was pressed down on during delivery and the mounts were slightly moved over...i bent them back and its fine now. Thanks
Old Sep 29, 2005 | 12:31 PM
DannoG35's Avatar
Overall how do you like the Fuji? Was there other exhausts that you looked at too? Lastly how much of a sound difference did you notice?
My reasoning for asking this is because I have been contemplating on what to get. I was set on the Fuji but then I was thinking of the HKS highpower for a bit louder exhaust plus its a true dual. Sorry this is off your topic but I see that you have been given all the right answers to your questions. Thanks
Dan
lamessi1018
Engine - Exhaust
Oct 20, 2015 04:24 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
erich2780
Sep 3, 2015 03:23 PM
