Fujitsubo Exhaust + Crawford Cats?
Old Nov 15, 2005 | 02:31 AM
nosey's Avatar
sensors from the high flow cats?? maybe?
Old Nov 15, 2005 | 03:31 AM
TedRuxpin's Avatar
Id like to know about the CEL also. Im about to install the high flow cats in a week or 2.
Old Nov 15, 2005 | 11:24 AM
iwantacookie's Avatar
I have a question about this setup too...
will it be enough to support a vortech setup or would i need something with bigger piping?
Old Nov 15, 2005 | 11:27 AM
SI_G35Coupe's Avatar
well the piping on the Fujitsubo exhaust is 76mm (3"). i would think with a good set of headers and either the high flows or test pipes, you should be just fine for the Vortech.
perhaps some of the F/I gurus would chime in?
Old Nov 15, 2005 | 11:37 AM
Meatshackle's Avatar
Deep Sea Moderator
Fujitsubo will be fine for your Vortech.
Old Nov 15, 2005 | 01:40 PM
Gaaaar's Avatar
Wow great job man, THanks alot. So did you notice any performance gains with the addition of the cats, ypipe and exhaust?? or it was strictly sound?? I wonder if gettin a borla exhaust instead of fuji and with the same setup would be lower or louder in noise.
Old Nov 15, 2005 | 02:44 PM
Those are really good sound clips... best i've heard/seen
Old Nov 15, 2005 | 03:26 PM
Deep Sea Moderator
Borla is much louder.
Old Nov 16, 2005 | 12:24 PM
did i feel a gain? yes i did. however, i will not post definitively until i get the car dyno'ed again... last time she got strapped on a dyno things were alittle screwy... it only turned like 230hp (granted it's a 5AT but still, that's aweful low). this was extremely surprising to me as the car definitely feels quicker than stock. my AFR was alittle wonky though, so that might be the reason for the low numbers
Old Nov 18, 2005 | 06:19 PM
GruppeS's Avatar
Former Vendor
Hey guys,
Just want to let you guys know that I am running a great deal on the Fujitsubo exhaust right now if anyonen is interest. This piece is great for people that wants a good looking exhaust and a little bit of a gain with min noise.
Please give me a call if you are interested.
Thanks,
Tom
Old Jan 17, 2006 | 09:04 PM
rkang915's Avatar
Does the megan y-pipe fits the fujitsubo exhaust??
Old Jan 18, 2006 | 01:57 AM
escobar929's Avatar
this is a great exhaust, i luv mine. cant say enough about it. not too loud but just right. its deep w/ a hint of exotic, best sounding exhaust IMO
Old Jan 18, 2006 | 09:20 AM
e420x's Avatar
Mod Junky!
Does this exhuast drone at all on the highway? I drive about 70 miles a day on teh highway and want to make sure I get something that will not drone or hum during highway driving
Old Jan 24, 2006 | 12:50 AM
rkang915's Avatar
Im plannin to get the fuji exhaust with megan y-pipe and i was wondering if it would fit? am i gona have any airflow restriction on this setup?? help thankx
fuji y-pipe is too much$$$ i rather spend it somewhere else. Anyone with this setup??
Old Jan 25, 2006 | 09:18 PM
  #30
do you happen to know the diameter of the piping on the Megan pipe? Fujitsubo midpipe (where it meets the y-pipe) is 76mm, 3". i got the Fuji Y-pipe b/c it looked very well put together, has a balance tube between the 2 long runners, and had one of the largest exit diameters (76mm).
that being said... any Y-pipe is basically the same... just a set of stainless steel tubes. i'm sure the Megan will be fine (assuming you're not FI or something where MAXIMUM flow is critical). just make sure the welds are quality as i've heard some ebay knockoff Y-pipes can crack where the flanges are welded on
