Lost the resonator on my G35S, 250 rpm less at 80
Old Aug 8, 2003 | 01:49 PM
3point5SE_Auto's Avatar
I had the resonator cut out of my exhaust system on my G35 Sedan, that thing weighs like 50 pounds. Definitely lost some torque, but my cruise rpms at 80 mph are 250 less (2850 rpm at 80 in 6th gear)
I am in the middle of an ECU reset, which in my experience with the VQ35DE has been the answer to torque loss following mods.
This is not a mod to be done in and of itself. the exhaust sound is very shitty right now, sounds like a fart can with the stock muffler. I have a dual tip shiny magnaflow on order 14830 model. I should have that on early next week. The resonator removal cost me 60.00 including fabrication/parts for a bolt in 2.5" pipe and reducer.
Better Life thru Chemistry
Old Aug 8, 2003 | 04:12 PM
RacerX's Avatar
Re: Lost the resonator on my G35S, 250 rpm less at 80
<hr></blockquote>
I hate to say it, but you must be mistaken. Speed at a particular RPM in a particular gear is a function of ONLY ONE THING: gearing.
This has nothing to do with your exhaust, even if you did manage to increase horsepower.
Unless you changed your transmission 6th gear ratio (god knows how one would do this!) or your rear axle ratio, (didn't know any alternatives were available here either), OR, more than likely, you changed tire diameter.
An increase in tire size (outer diameter) could definately cause a drop in RPM at a given speed.
04 G35 6MTS Aero Kit/Nav/Prem/Wint (Hopefully Sept 03)
Warning: Objects in Mirror Are Losing!
Old Aug 8, 2003 | 05:29 PM
are you sure?
am I mistaken?
OMG!
That has never happened before.
Sorry y'all. my 80 mph cruise rpm is 2850 in sixth, stock tires etc. I could have sworn I was at 3000-3100 rpm before, what are y'all at?
I understand the whole mechanically linked thing, piston to wrist pin to connecting rod to crankshaft to flywheel to clutch/pressure plate to tranny gears to driveshaft to differential to axle to wheel.
so where am I screwing up here? Is the cruise rpm not that high? What do y'all see at 80 mph? Stock 17's with Goodyear GS-D's. DoI have a problem with my car????? Or just my old age/memory? HaHa
Old Aug 8, 2003 | 06:52 PM
RamboRami's Avatar
G35driver.com Moderator
i've got a coupe and its around 2800 @ 80mph
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 10, 2003 | 06:34 PM
beavisoncrack's Avatar
I was thinking about this mod (i.e., replacing the resonator tube with the Z350 tube. People have said that it is "louder" but not that it sounds like a fart can. Now I'm worried. Does it really sound worse?
Old Aug 11, 2003 | 10:41 AM
cato's Avatar
SouthernComfort Moderator
I believe you are referring to the intake, this post is about
the exhaust. The 350Z intake duct does not make the
car sound like a shitcan! Mine sound MUCH better than
prior to the 350Z duct.
2003 Twilight Blue Sedan 5AT, sunroof, leather,
splashguards, GG red 7 wire Hypergrounding kit, 350Z intake duct, K&N filter.
Old Aug 11, 2003 | 10:56 AM
yes the resonator on the exhaust needs to be accompanied by an aftermarket muffler. after driving it this weekend I lost a noticeable amount of low end torque and gained a like amount of high end (>4000 rpm) hp. This may not be worth it, I will dyno early next month. I have a magnaflow 14830 dual tip muffler coming soon. If that does not fix my problem, I will throw in a 18" or so glasspack. Next step after that is a dual muff setup with matched length b pipes for that quad pipe look in the back. I don't know if it will work.
thanks for the stupidity check on me. I need that every now and then.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
