Exhaust Install order?
Old Jan 12, 2006 | 11:25 AM
e420x's Avatar
Mod Junky!
I want to eventually redo the whole system with exhaust and headers and converters. Can i go tiwht a cat back exhaust and install it and then add high flow cats after, then add headers later? Does it make sense I do not want to spend all the $$ at once so want to know if i can split it up.
Old Jan 12, 2006 | 12:43 PM
GT-Ron's Avatar
Depends on what's most important to you, gains in power or gains in volume.
The G's OEM rear-section seems to flow pretty good, yet the cats are pretty restrictive, with the headers and Y-pipe next in line.
Personally, I plan on keeping the OEM rear-section in place for good. That being the case, I'll install the headers, cats, y-pipe and splice a reducer cone onto the OEM rear-section pipe all at the same time, to avoid added installation cost.
I'd suggest having the headers and cats installed at the same time, both to avoid repetitive install costs AND to get the biggest gains at one time. If possible, do the Y-pipe at the same time for the same reasons. The rear-section could easily be saved until last. The cats and headers will increase your exhaust volume as well.
The other option is doing just the rear-section first if you're really looking for just an increase in volume.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Xfactor
Dec 1, 2019 12:52 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
