For those who use K&N drop in air filter
Old Jan 17, 2006 | 10:55 PM
zoomzoomers's Avatar
Originally Posted by andy2434
If I am not mistaken, I think that partshipperdave said that the 8% discount was good til 12.31.05. You may want to check with him.
Thanks andy. I'll check it out.
On a side note, does anyone know if there is a front strut tower bar available for the G? Also, if it will fit with the MREV plus mod? Thanks.
Old Jan 18, 2006 | 08:32 AM
SixFive's Avatar
No strut tower bar has been sold for the G that I know of yet. The Z can not be used as the AC lines are conigured differerently and the plenum is a problem I believe. Anyone with a spacer or revised plenum would have a problem even if it were available.
I am interested in having an X brace designed for the G but I haven't found anyone that can spec it out. I have a fabricator that can do it but he needs a drawing...
Old Jan 18, 2006 | 01:36 PM
Well DC sport advertises that they have a front STB for the G. I'm not completely sure as I haven't investigated this yet. As for the X-brace check out GT-spec they have a X-brace for our cars.
Old Jan 18, 2006 | 02:29 PM
SixFive's Avatar
I wonder what you have to do to get the DC one installed. I have a plenum so probably wont be checking it out. But thanks for the heads up on the x brace!
Old Jan 18, 2006 | 02:57 PM
Sure thing. I'm planning on getting the MREV plus so I don't know if a STB will fit but I'm looking for one that will. If I find one I'll be sure to let you know.
Old Feb 25, 2006 | 06:21 PM
gqgeos's Avatar
does anyone have any pictures on how to install the air filter on a 2005 G35? or instructions ?
I was able to replace mine but it was a real pain I unhooked the 4 latches and then had to push the air filter housing and pull the air filter out. it was REALLY tight pulling it out
Old Feb 25, 2006 | 07:41 PM
Well, I've yet to see what the DC sport one looks like, but check the one from Wargod on this forum he's selling his version for $400. That version will definitely fit with the plenlum spacer as it goes in front of the motor instead of on top.
Old Feb 26, 2006 | 10:06 AM
SixFive's Avatar
400 seems a tad high for a strut bar. I think I like the idea of the GT spec bar. There seem to be several configurations using 3 or 4 different pieces. I am wary of the one in the rear that leaves little or no clearance for the exhaust pipe. I'm thinking about the front bar and the 4 point mounted brace. At that point if I need any more rigidity I should just get the M!
Old Feb 26, 2006 | 01:17 PM
99atlantic's Avatar
once a year
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
JG_G35
Sep 7, 2015 09:35 PM
