Complexity of header install?
Old Jan 24, 2006 | 01:05 AM
99atlantic's Avatar
Right now I'm trying to decide who to have install my topspeed pro-1 headers (engine doesn't have to be lifted off its mounts)
2 possibilities
Shop 1 - has installed about a dozen headers or so on various 350z/g35s, so they know what they're doing
Shop 2 - works primarily on volvos, but is owned by a friend so I can get ~50% reduction in the cost of labor
Obviously I like the cheaper rate that my friend can offer me, but I"m curious - if his staff has never worked on a g35/350z before, is there anything 'tricky' about the header install........they've been in business 25yrs or so, so it's not like they're newbies doing this..........obviously you ask them and it's like 'yea, we do it, no probs', but i'm curious from anybody on here whose done the header install, would a seasoned mechanic be able to do it w/o problems, or are there twists&turns that you'd only learn from doing previous models.
Old Jan 24, 2006 | 07:02 PM
g35rcr's Avatar
its not hard just time consuming...a good mechanic can do it...
Old Jan 25, 2006 | 06:14 PM
99atlantic's Avatar
this is probably a stupid question ( ) but what type of header installs are there? I was talkign with him and he asked if it was a bolt-on header install or the other kind..........what's the other kind? I figured that all headers were bolt on?
Old Jan 25, 2006 | 06:32 PM
ballisticus's Avatar
I cant imagine what he means other than some heads use a bolt threaded through the header flange into the head, while others have a stud threaded into the head with a nut to secure the header flange. I guess he is just trying to guess how many studs he breaks off and or how many aluminum threads he has to helicoil. All part of the labor estimate.
Old Jan 25, 2006 | 07:20 PM
Dan_K's Avatar
I think they need to tilt the engine as well. I believe on Strupt headers will allow you to install with the engine in place.
Old Jan 26, 2006 | 01:30 AM
99atlantic's Avatar
i've never read anything about topspeed pro-1 headers needing the engine lifted....given that people with these headers have said the engine doesn't need to be lifted, i don't think it has to, lol
Old Jan 26, 2006 | 12:03 PM
CBRworm's Avatar
20 Year Member
There are some non-bolt on headers that you have to weld the collector to your exhaust - typically they are longer than stock and require custom exhaust.
Bolt on headers will already have a flange to bolt on to the catalytic converter.
Old Jan 26, 2006 | 12:44 PM
g35rcr's Avatar
only the crawfords require tilting the motor...i went with strup headers for design and price...also they have dyno proven results
Old Jan 26, 2006 | 06:44 PM
G35_TX's Avatar
http://zchickz.com/garage1.htm
There is a header how-to here.
Old Jan 26, 2006 | 07:41 PM
99atlantic's Avatar
i like borla's better - it looks much simpler ^_^
http://www.borla.com/media/installations/17221.pdf
Old Jan 26, 2006 | 07:55 PM
gary c's Avatar
Header install.....
I tend to go with the people that have knowledge
and experience to do the work. They have the
ability to do the job correctly. You won't have to
be concerned about them $crewing up your car.
Old Jan 27, 2006 | 12:32 AM
DaveB's Avatar
There are so many steps missing from those instructions it's hilarous. They act as if you're installing these headers on a motor connected to an engine stand.
Old Jan 27, 2006 | 01:25 AM
Rookie84's Avatar
Installing headers is a pretty simple work. It's just time consuming. Experienced shops can get it done quicker, but it is hard to screw up on header install unless you take it to a real shady place.
Old Jan 27, 2006 | 01:42 AM
99atlantic's Avatar
i know, but the instructions make me feel all warm and fuzzy inside - almost like i could do it myself ^_^
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
Machine Head
Sep 4, 2015 07:22 PM
linedr89
Aug 17, 2015 05:11 PM
yosip1115
Engine - Exhaust
Jul 22, 2015 01:47 PM
