Can anyone confirm that the 05-06 G35 airboxes have a built in velocity stack?
Old Apr 5, 2006 | 06:44 PM
OC 350GTCoupe's Avatar
I know the 350Z does, just want to make sure the G35's do too.
Old Apr 5, 2006 | 09:13 PM
03-04 Airbox from 350Z: (no Velocity Stack)
05-06 Airbox from 350Z: (Velocity Stack)
Old Apr 5, 2006 | 09:18 PM
aleok's Avatar
um whats a volocity stack do?
Old Apr 5, 2006 | 09:36 PM
Supposedly speeds up and smooths out the air flow.
Old Apr 5, 2006 | 10:41 PM
godmans's Avatar
IMO both of them have a velocity stack, just that the 05-06 have a larger lip =)
Old Apr 5, 2006 | 11:27 PM
Andy2434's Avatar
Here are a couple of more pics for an '05.
[IMG][/IMG]
Old Apr 6, 2006 | 01:07 AM
99atlantic's Avatar
i do'nt think g35s have a velocity stack, only 350z???
Old Apr 6, 2006 | 06:09 AM
nouse4aname's Avatar
yeah, they don't. was being sold as a G upgrade at performance nissan.
Old Apr 6, 2006 | 07:05 AM
g35rcr's Avatar
save your money and buy an intake setup that has a velocity stack on a cone filter like...jwt, stillen, or weapon-r
Old Apr 6, 2006 | 10:44 AM
FenixL1P's Avatar
like andy2434 has shown, g35's do have a velocity stack... i know mine does since i've swapped out oem filter for an amsoil nano drop-in filter and realized it had a velocity stack...
A velocity stack is for smoothing out the intake air flow.... makes air flowing through the intake manifold more laminar and with slightly higher pressure as opposed to air flowing turbulently and causing pressure drop....
Old Apr 6, 2006 | 10:46 AM
[IMG][/IMG]
Can i see the other side of that airbox?
Old Apr 6, 2006 | 02:12 PM
THanks man, appreciate it. How do you like the amsoil drop in filter? Im on the fence between a "Green" air filter, nismo, or blitz.
The amsoil filter is oiled correct?
Old Apr 6, 2006 | 06:34 PM
FenixL1P's Avatar
The amsoil nano filter i installed is a dry non-oiled filter and can be cleaned and re-used, albeit vacumming the dirty side, so no chance of over-oiling to foul up the MAF sensor... airflow should exceed oem filter and should work as good as k&n filter... its light blue in color too... about the same in terms of cost but not sold everywhere although you can get it directly thru them from their website.
Old Apr 6, 2006 | 08:40 PM
Andy2434's Avatar
Here is the back side of the stock '05 airbox. This is where the MAF would bolt up to. Inside the box is the blue Amsoil Nano drop-in filter. I originally used a K&N filter. I switched to the Amsoil for better filtration and ease of cleaning. Now, with the Stillen Hi-Flow set-up, I am back to washing and oiling.
[IMG][/IMG]
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
yoyoyo8
Aug 12, 2015 03:04 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
