Tornado-air
Re: Tornado-air
Hahaha... This has been discussed many times... well, it was discussed one time, but everyone always laughs and remembers that one discussion whenever someone new asks. In a word: No. If you want a more in-depth answer, I can point you to the old post.
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
G
Re: Tornado-air
GeoBau,
Could you? This guy at work told me and since I don't know much about cars I figure ask the experts. I like to keep my G stock (no major mods) and so I if it work it would be a good addition.
Thanks
Thanks
Re: Tornado-air
Always look for the key words, like 'up to' or 'your actual may vary', etc. Sure on a poorly designed vehicle it might make difference, but for 98% of cars it will do squat or make things worse.
Just watch the stupid infomercial carefully or the <a href="http://www.tornadofuelsaver.com/">website</a>. Then think about it.
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages.
Re: Tornado-air
It keeps your windows up to 25% cleaner also. If they aren't dirty then it will spay your cat.
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Re: Tornado-air
It works on old carburetor engines. Newer fuel injected engines can't benefit since the intake runners are designed so well from the factory. I have been acquainted with some of those ppl on the informercial, and they are not liars. But then again... the cars that these things were installed on were like 1988 chevy caprices and crown vic's.
Re: Tornado-air
Hey guys,
I havnt been around in ages but its funny to see all the exact same questions being asked.
Anyhow, from a fluid mechanics standpoint the "tornado" is really dumb.
For instance, air flowing in the tube has its highest velocity in the center of the tube and goes down to zero on the boundry layer against the tube. The tornado forces more air out of the center of the tube which has the highest velocity and the least resistance towards the outside walls.
The "swirl" effect of cylinder heads have a reason for the swirl, the air needs to be pushed towards the walls of the cylinder bore to create a better and more consistant mixture. The intake tubes have no reason for this "swirl" because its not doing anything except restricting the flow.
I should do a CFD on this to prove it but that would be a waste of time.
Dan O
Dan O
