rough idle after install?
Old Apr 23, 2006 | 07:03 PM
gfx35's's Avatar
Just installed crawford plenum on friday,but car has a rough idle. Haven't driven it much since install. Do I have to do a reset or will the car eventually learn the new plenum on it's own?
Old Apr 23, 2006 | 07:10 PM
mikesj's Avatar
check to have any air leak
hope it helps,
Mike
Old Apr 23, 2006 | 08:24 PM
EZZ's Avatar
EZZ
What type of rough idle...does it go under 600 rpms and then go back up suddenly or is it at 650rpms but still feels rough.
Old Apr 23, 2006 | 08:57 PM
Andy2434's Avatar
Use care to be sure that all bolts are torqued properly and all existing connections have been secured and tightened properly, as well. If everything checks out to be right, perform a simple ECU reset via the pedal method.
Old Apr 24, 2006 | 02:21 AM
gfx35's's Avatar
Yeah it goes under 600, then suddenly pops back up. I'm takin it for a little rride later to see if it smoothes out, if not I'll do the ECU reset by pedal like andy2434 mentioned.
Thanks Guys.
Old Apr 24, 2006 | 12:50 PM
jbone's Avatar
'04.5 Black 6MT Coupe
Thanks Guys.
The ECU's probably just trying to relearn the A/F mix. I put an ez 50 miles on mine with some WOT and it ran just fine. Mine idles around 650, sometimes it'll dip below 600 for a sec. I wouldn't worry about it just yet. Pedal reflash wouldn't hurt either
Old May 3, 2006 | 10:00 AM
BocaCoupe's Avatar
G's Up, Ho's Down
Mine is at 650rpm, but still feels rough.
Raiderpolo15
18 Inch
11
Jan 30, 2017 03:25 AM
mtlruss
Dec 20, 2015 01:51 PM
Silver tiburon
Sep 4, 2015 07:17 PM
nosam1g
Aug 22, 2015 11:58 PM
ghost_g35
Aug 7, 2015 10:31 AM
