MD 5/16" Spacer Question - Gasket between lower and upper plenum?
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
Originally Posted by Hydrazine
You don't need to buy anything with the plenum spacer kits. It comes with everything you need.
Thanks. I really want to be as prepared as possible for the magical day of install.
It will work either way honestly. Leave it in if you want to keep it for later use, or take it out if you question the integrity of the metal gasket.
Tony
Tony
Originally Posted by DaveO
Here's my two cents.
For those with a spacer having "built in" gaskets--you'll still need to properly seal the lower collector's oil gallery. Therefore, I'd recommend leaving the full factory gasket in place. A double gasket here won't hurt anything as long as they're both in good condition.
DaveO
DaveO
Originally Posted by Gangreen350
Question what plenum is better suited for our car (G35). Brand and thikness
1- It will set under your engine cover.
2- It comes with isolation thermal gaskets and valve body coolant valve.
3- It comes with everything needed, just use your in-lbs torque wrench and your done
Last but not least DYNO PROVEN.
rezendvous420
May 31, 2020 01:26 PM
