Z-tube on a 06 6MT coupe
Originally Posted by 06BLACKMT
Hey I'm picking up my new 06 today!!! I was looking to do the Z-tube as my first mod, so any info on it with the 06 would be great!!
BTW, a Z Tube is a direct replacement. Its just the tube that goes between the throttle body, and the stock airbox or cone type filter (weapon r, popcharger)
Originally Posted by OC 350GTCoupe
Check your PM.
Originally Posted by weiren
Anyone put a z-tube in a 06 6MT coupe? How difficult is it to do, are there any mods or is it a straight replacement?
All you need are a 10mm and 8mm socket/rachet, nut drivers or a phillips and a flat headed screw driver. The sockets will make the task go much easier. The very first time it may take you some 30 minutes to remove and replace. Subsequent installs/removals will take you a mere 5 to 10 minutes tops, once you have done it once.
great
Awesome, thanks a lot guys. I'll be sure to get up some pics of the new coupe soon. Still getting used to the 6speed
Guys... noob question...
What's the 350Z intake tube do for you on a G35 Sedan? Is there a noticable power bump? Would it make a G35 Sedan sound more like a Z? Is there benefit to adding a Z-tube without a JWT Popcharger? Can a Popcharger be put on without a Z-tube?
No noticable HP gains.
Yes you can add either with or without the other.
The z tube simply d/n have the baffles like the g tube.
Sound is the major advantage, and works best w/ other breather mods.
From what I've read.... K&N drop in + Z tube + 5/16 MD spacer. (or 1/2 spacer) is one of the better valued upgrades. Note that this is the only intake mod I've done to a G, so I can not compare to other aftermarket setups.
Personally... I'm very happy w/ the results. Sounds great at 3k RPM+, and the mental/butt dyno can tell the difference.
Good luck!
Good luck!
So is there a significant difference in sound between adding a JWT Popcharger to a G35 Sedan vs. adding a JWT Popcharger *AND* a Z-Tube?
Has anyone done a comparison?
What I'm trying to get is a more agressive sound without changing out the exhaust (it's a leased car, and I can swap in and out an intake quickly if required).
It's more aggressive under load. It sounds mean....but only when you want it to. As far as the sedan goes, the exhause is fairly quiet so you only hear the engine. When I have time to install the HKS rear section, she'll be singing an entirely new toon.
Brodys_GCoupe
Nov 7, 2015 08:06 PM
