Heading to the dyno tommorow
Old May 15, 2006 | 01:25 AM
CB_Skyline_03's Avatar
Whats goin on guys,
Well, i just installed my JWT Pop charger and had my ecu reflashed by Technosquare. I will be heading out to see if i have improved the power of my g35.
Current mods-
2003 g35
Ichiban Test Pipes, Fujitsubo Y-pipe, A'pexi n1 gt exhaust, Crawford intake plenum, UR crank pulley, 350z intake tube w/ jwt pop charger, F-spec reflash.
19" Volk le37t
any takers on bets? looking for 250+
Old May 15, 2006 | 01:31 AM
DaveO's Avatar
Originally Posted by CB_Skyline_03
Whats goin on guys,
Current mods-
2003 g35
19" Volk le37t
Auto / Manual / Coupe / Sedan / Dynojet / Dynapac / Mustang / ?
Old May 15, 2006 | 01:43 AM
papagz's Avatar
prob right around 250, 255 max
Old May 15, 2006 | 02:52 AM
99atlantic's Avatar
Old May 15, 2006 | 03:02 AM
godmans's Avatar
Well
he hasn't even specified what car / dyno he has or is going to use..
there is no point on betting lol...
Old May 15, 2006 | 10:53 PM
my bad.. it was late for me when i posted it but i was a little tired.
2003 G35 COUPE/ 6mt/40k mi/ 248 Dynojet
256.92 whp and 243.02 Wtq....not bad at all.
1st run was all of the above minus pop charger and reflash.
10th run was all of the above installed
im actually very pleased.
Old May 16, 2006 | 05:51 PM
LMG_35C's Avatar
Looks good. By chance do you have a view of what the Air/Fuel ratio was for each of the plotted runs? Also, if you don't mind, can you tell what's meant by the F-Spec reflash... was that a custom flash based on your mods?
Tks
Old May 16, 2006 | 09:13 PM
i forgot to grab the A/f ratios, but it was still a little rich on the top end after 5k.
technosquare's f-spec is a full flash- they mess with everything from ignition timing, fuel adjustment, rev limiter ( for some reason it wouldnt rev out to 7100, but it didnt matter, it was already falling off), and some other minor tweaks. Check out technosquareinc.com
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
