Coupe Carbon Fiber Engine Cover.
Are these the exact same? (minus the sticker)
http://cgi.ebay.com/ebaymotors/INFIN...spagenameZWDVW
Also, any other shops that sell these? (UT only has the flat one as far as I know)
Originally Posted by inTgr8r
Fitment is the same for all VQ.
You can also use the Z cover which helps the plenum to run cooler.
Originally Posted by codeflux
the Z cover will need to be cut to fit G35 - like i did.
dont order it dude... i got the same one from the same person a while back and its all cracked cuz of heat. Also if you tighten your screws too tight it'll crack all over... i'd advice on getting a better one if ur gonna spend the money, one from a name brand company that uses better carbon fiber.
I started to put mine on last week but read several post that stated the covers trap heat. That seems to make sense.
Isn't it better to run without them?
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
joedaddy1
Jul 28, 2015 02:58 PM
