If i was too order from customautomesh.com for the nismo replica, would it fit??? or is this just for authentic??? same for gialla if i got the SP replica?? thanks
It will fit. I used their mesh for KurumaZ bumper(actually ordered ones for Greddy and had no problems since KurumaZ bumper is modified Greddy bumper) and replica KS rear. All that matters is the demensions, so you should have no problems at all.
I actually ordered this for my Nismo poly replica. It is not the same size as the vents in the front and you will have to Trim it. Also it doesn't screw to the bumper, they recommend you you epoxy and glue it. I am getting it installed on Friday and will post a few pics to show you how it looks. I held it up behind the bumper and it looks great.
Moderator
We always cut the mesh a little larger so that you have ample material to get the best fit. We would rather provide too much then not enough. Since 99/100 replicas are made from molds of originals, we have never run into an issue of mesh not fitting a replica.
hey whats the difference between the 1/4 inch and 1/8 inch mesh??? it says 1/8 available upon request...just wondering
Quote:
Sounds like the distance between the solid pieces in the mesh. The 1/8 will be a tighter mesh.Originally Posted by MikeIvoryg35
Moderator
Pics are on the website. 1/8 is a tighter weave mesh and thinner. We reco NOT to use the 1/8 on front applications because it really isn't rigid enough. It may work for a grill (Data or Gialla), but more anchors should be used to keep it tight. Def not reco'd for large bumper opening to protect FMIC or anything like that. It is perfect for the KS rear b/c teh tighter mesh hides the rear bumper much better and yields a cleaner look.
- FS: 2007 G35x Sedan Ivory Pearl
- FS[NorEast]: DPE s20 for sale
- FS: 2008 Infiniti G35X - Mods
- Limp mode CAI
