What to do with engine cover and spacer?
Old Jun 8, 2006 | 10:54 AM
Archangel's Avatar
I have the MRev mod from Motordyne, and the engine cover rubs on the driver's side against the bottom of the hood. I was going to paint the engine cover, but that paint would be gone in no time. Any thought's on how to dress up the engine bay with this problem? I don't know if removing the hood liner would help as it isn't very thick and I'm not wild about those half covers. That would really only leave the option of cutting out the section that rubs, or a different hood. If anyone has tackled this problem, pics would be great.
Old Jun 8, 2006 | 07:32 PM
Andy2434's Avatar
Hmmm . . . What size spacer do you get with the MREV? The 5/16" should allow for the engine cover to clear. You might try removing the 4 rubber grommets, which are located under the engine cover. That will give you between an 1/8" to 3/16" of additional clearance.
Old Jul 18, 2006 | 08:48 AM
Archangel's Avatar
^It took me a while to get back to this post, but thanks for this suggestion. It seems that the Driver's side bolt nearest the firewall was not set properly and therfore not holding the cover down. I took the rubber grommets out anyway. Now to repaint the areas that rubbed.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
