Ground clearance - Body Kits.
Old Jun 12, 2006 | 01:28 PM
benxnet's Avatar
Unfortunately, when browsing for all the different body kits, nowhere do vendors mention the ground clearance of each.
I'd be interested in getting a body kit, to complement my airplane look, but need input on ground clearance - since I'd need as much ground clearance as possible.
So, for all body-kit owners out there - I'd appreciate feedback on the maximum ground-clearance from your installed body kit.
Thanks.
Old Jun 12, 2006 | 01:35 PM
blazinZ's Avatar
i jst have a data lip lowered on hotchkis springs and have about a 3.5 inches on the sides and a little over 4 in the middle and thats just a lip with a mild drop.
Old Jun 12, 2006 | 02:27 PM
Rookie84's Avatar
I have Kuruma Z and I have about 5 inches on stock suspension I think. Make sure you get urathane bumper as I scrape almost everywhere and I would have cracked the bumper if it was made of fiberglass.
Old Jun 14, 2006 | 10:53 PM
x7original4x's Avatar
how good is the frp reinforced stuff
Old Jun 15, 2006 | 01:04 AM
truplay8's Avatar
THE BATMOBILE
im on stock suspension and have an ings lip and i think im about 6 inches from the ground, which isnt enough down here in south florida
Old Jun 15, 2006 | 04:13 AM
cutiewolf's Avatar
wat about kentstyle and greddy with 19 or 20 rims on stock spings?
Old Jun 15, 2006 | 04:33 AM
SURFJ9009's Avatar
Good question. I am thinking bout the Kenstyle kit on 20's too.
Old Jun 15, 2006 | 10:11 AM
afr0puff's Avatar
Supa Dupa Moderator
My Nismo front scrapes on 70% of driveways, parking lot, and drive-thru entrances. My kenstyle side skirts scrape on 90% of speed bumps.
Old Jun 15, 2006 | 10:51 AM
GT-Ron's Avatar
I've had good luck with driveways, etc. with my NISMO front, but I'm also still at the OEM ride-height.
That said, I ran over a shoe in the roadway (maybe 15-20mph) and it was enough to clip the bottom of the bumper. Being fiberglass, the resulting push into the headlight caused spider-web cracks in the paint right under the headlight. Time to hit the bodyshop for those other details I want done.
Old Jun 15, 2006 | 12:06 PM
Down_Shift's Avatar
Avoid Kenstyle/Topsecret/Greddy... Prob the worse for clearance (including sideskirts). They tend to make them come out more in the front also, so it will be harder to clear things.
I've had the Nismo and the TopSecret on my car.. The TopSecret is a hard bumper to drive on. I'm on Stechs. I can't avoid soda cans on the road by going over them anymore.
Old Jun 15, 2006 | 12:15 PM
abcdefGGGGGG's Avatar
+1 on the nismo front bumper. it also picks up alot of rock chips because of the flat plow-like design
Old Jun 15, 2006 | 12:18 PM
Down_Shift's Avatar
!!!!! +2
Old Jun 15, 2006 | 12:38 PM
benxnet's Avatar
Stillen..
Stillen anyone?
Old Jun 24, 2006 | 02:15 PM
Hugen35's Avatar
Trendsetter
Greddy?
Old Jun 24, 2006 | 02:22 PM
plaing35coupe's Avatar
Sneaker Whore
Afropuff is your car lowered and what size rims are you running on?
