Alternative Front License Bracket
Old Jan 11, 2003 | 07:18 PM
Hooter's Avatar
Rather than drill holes in the front bumper of my coup, I made a bracket mount, taking advantage of the front female receiver for the tow hook.
The list of materials needed are:
1 - 6 1/2" long 16mm x 2.0 pitch allthread
4- 16mm nuts
2- lock washers
1- flat washer
1- suitable license plate bracket
Screw 2 nuts together toward one end of the allthread leaving 7/8" of thread exposed to screw into the female threads of the tow hook receiver.
Next screw a nut onto the other end, leaving 1 1/8" threads exposed.
I then coated the non-functional threads, between the nuts, with a plastic dip coating to protect against corrosion.
Put a lock washer on the double nut end and screw into the tow hook reciever and tighten. You will need to unscrew the one nut toward the outside end of the allthread and install another nut right at the same end, forming a double nut connection, so that you can use it to tighten the mount into the receiver.
After tightening, remove the end nut and screw the second nut back down to position, leaving the 1 1/8" thread exposed again. Installl a lock washer, the license plate bracket, a flat washer and the remaining nut. Tighten bracket to mount. Install license plate to bracket and done.
Still ain't real pretty, but keeps the plate away from the car's bumper, and the law off yours.
Pictures attached, I hope!
Hoot
Old Jan 11, 2003 | 07:30 PM
Hooter's Avatar
Re: Alternative Front License Bracket
Pic 1 is initial assembly and license bracket I used. Note plastic coating on threads inside of nuts.
Hoot
I really do have some pictures. If anyone is interested, tell me how to post them and I'll try again. Hitting browse, selecting the file and then hitting continue doesn't get it done for me.
Thanks<P ID="edit"><FONT class="small"><EM>Edited by Hooter on 01/11/03 04:34 PM.</EM></FONT></P>
Old Jan 11, 2003 | 08:05 PM
Merlin's Avatar
Staff ALUMNI
Let me try. Seems to work, must be on your end somehow. Try making it less than 100kb if it is larger.
Merlin.
<P ID="edit"><FONT class="small"><EM>Edited by merlin on 01/11/03 05:06 PM.</EM></FONT></P>
Old Jan 11, 2003 | 08:31 PM
Hooter's Avatar
Pic 1, smaller. Thanks Merlin!
Hoot
Ok, which "continue button do I hit after inserting the file by using browse. Is it the continue directly under the "browse" or the continue down in the edit screen?<P ID="edit"><FONT class="small"><EM>Edited by Hooter on 01/11/03 05:37 PM.</EM></FONT></P>
Old Jan 11, 2003 | 08:43 PM
Hooter's Avatar
try again. Moved pics from desktop to zip.
Hoot
Old Jan 11, 2003 | 08:48 PM
Hooter's Avatar
OK, maybe I got it now. Pic 2 shows the mount installled into the tow receiver and just enough of it protruding from bumper to attach bracket.
Hoot
Old Jan 11, 2003 | 08:56 PM
Hooter's Avatar
Last pic shows bracket bolted to mount.
At first I had bought an acrylic license plate cover, drilled a hole in it for the mounting threads and inverted the cover and mounted the license plate to the reverse side of the cover. The license plate bowed a little due to the nut between the plate and the acrylic. Plus I was concerned as to how the acrylic would hold up at spped. I found this aluminum license bracket at a truck mechanic shop. It came off a Peterbilt. I drilled a hole for the mount in the bracket channel and the nut fits into the channel without bowing the plate.
Still don't really care for it, Nissan could have done better on this item and Utah could quit requiring the stupid plate.
Hoot
Old Jan 11, 2003 | 09:14 PM
Hooter's Avatar
I give
Hoot
Old Jan 12, 2003 | 07:51 AM
Hooter's Avatar
try again
Hoot
Note: the bracket is sandwiched between the two nuts such that it does not touch the bumper.
I may have to paint that bracket Diamond Graphite.<P ID="edit"><FONT class="small"><EM>Edited by Hooter on 01/12/03 06:09 AM.</EM></FONT></P>
Old Jan 14, 2003 | 01:01 PM
pestilence's Avatar
..thats a neat idea..
..pestilence..
Old Mar 22, 2003 | 07:21 AM
Hooter's Avatar
After several months of use, I am happy to report this mount works fine and does not loosen. After seeing several posts talking about an alleged dealer furnished version of this I have yet to see a pic of one that you could tell anything about. So, I thought I'd report on this again for those interested.
Hoot
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
crazy_g35s
Jul 20, 2015 02:30 PM
