Blinker Mod Question
Old Sep 24, 2006 | 12:30 AM
TomieG's Avatar
Can you mod the blinkers so they blink faster? Iv'e seen one done on a BMW. It loooks sick. (The blinker on your taillights)
Old Sep 24, 2006 | 02:34 AM
alphamatt's Avatar
think thats when your light is losing its life
Old Sep 24, 2006 | 06:03 AM
Silverbolt's Avatar
Right now, your front and rear are blinking at the same time. Use a relay to make them alternate. This will make them blink faster. Its simulating the same scenario as when of your blinker bulbs die, which allows more power to flow, and causes your signal to blink faster. I'm not 100% sure if this will work on our cars though. Just unplug your blinker bulb in the front, turn your signal on, and see if the rear blinker blinks faster. If it does, then use a relay to alternate the blinking, and you should get the effect you want.
Old Sep 24, 2006 | 06:18 AM
dofu's Avatar
20 Year Member
LED bulbs without a relay seem to do the trick for me...
http://www.superbrightleds.com/
Old Sep 24, 2006 | 11:04 AM
Sumlime311's Avatar
^^hahaha funny picture as your avatar
Old Sep 24, 2006 | 11:11 AM
TomieG's Avatar
What is a relay?
Old Sep 24, 2006 | 12:42 PM
Silverbolt's Avatar
Originally Posted by Tomiegunzz
What is a relay?
Go to your local Radio Shack and ask them. Its too much and too hard for me to try and explain... especially since the majority of my electronics knowledge is self taught.
Old Sep 26, 2006 | 05:36 AM
dofu's Avatar
20 Year Member
What is a relay?
Just get the LED plug and play bulbs... or you can use this unit SPW makes called the Run-About
http://www.spwusa.com/spw/sidemarkers.php (scroll to the bottom)
Th611
Oct 27, 2015 03:48 PM
Texasscout
35
Aug 16, 2015 11:07 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
