Seibon Hood HELP
Old Oct 24, 2006 | 04:41 AM
G352NV's Avatar
Never enough
I guess it just depends on what hood they ship. Some are better then others.
Old Oct 24, 2006 | 08:23 AM
Jim@Showstoppers's Avatar
adjust your latch. I've seen it a hundred times. If that doesn't work shoot me a PM and I'll give you some more pointers.
Old Oct 24, 2006 | 09:12 AM
G35SHAWN's Avatar
what's up...bro, can you please tell me how to exactly adjust the latch.
Old Oct 24, 2006 | 11:12 AM
there should be 2 10mm bolts that hold your latch mechanism in place. Simply unbolt the bolts and slide the latch mechanism down about 1/4-1/2". You may need to remove your front bumper to get at the bolts on the latch mechanism.
Old Oct 24, 2006 | 11:21 AM
G35SHAWN's Avatar
My bodyshop just install my new bumper yesterday, is there anyother way to do this without removing my bumper.
Old Oct 24, 2006 | 12:09 PM
k_hojnacki's Avatar
There are actually 3 for the latch mechanism. You will need to remove your grill, that way you can actually tighten the bolts down when the hood is shut.
Old Oct 24, 2006 | 12:41 PM
G35SHAWN's Avatar
Ok i am going yo sears to pick up 10mm wrench, wish me luck ......
Old Oct 24, 2006 | 12:48 PM
G352NV's Avatar
Never enough
Get the flex head gear wrench set. I wrench a TON and these are the best wrenchs Ive ever used! I thought you had already adjusted the latch. Thats how mine looked after adjustment. I guess I just got a real bad one,lol.
Old Oct 24, 2006 | 01:02 PM
G35SHAWN's Avatar
Thanks bro, i am on my way to sears...wish me luck
Old Oct 24, 2006 | 01:10 PM
GreenGoblin's Avatar
The goblin resurrection
wow that hood is nice
Old Oct 24, 2006 | 01:14 PM
Gilley's Avatar
I have had to use a hammer to knock the latch toward the rear of the car just so little. Then I adjusted the latch up and down to get the proper height.
Old Oct 25, 2006 | 09:38 AM
G35SHAWN's Avatar
Allright guys finally problem solved. You guys were rite all i had to do is adjust the latch which was easy, anways thank you everyone for your help especially bobshuai, G352NV & chucky...also carbonltd.
Old Oct 25, 2006 | 11:52 AM
bobshuai's Avatar
Kool bro, anytime. When I first saw the post at 2:30am in the morning your time then i knew you must be frustrated.
Old Oct 25, 2006 | 12:03 PM
G35SHAWN's Avatar
Exactly bro, thanks again so, much i really do appreciated a lot.
Old Oct 25, 2006 | 05:14 PM
  #30
truplay8's Avatar
THE BATMOBILE
pics now shawn
