center grille removal coupe help
Old Nov 12, 2006 | 01:36 PM
BremboBoy's Avatar
Hello all,
I tried searching but I could not come up with any useable instructions. I need to get off the front grille but I cannot get off those two clips that are on the top part of the bumper at the corners. Any help?
Thanks
Old Nov 12, 2006 | 01:58 PM
Triji's Avatar
just pull gently towards yourself, they are slid in just like the bottom clips. Use gentle force and it will come right out.
Old Nov 12, 2006 | 01:59 PM
Triji's Avatar
PS, make sure you take out the plastic rivits holding it in on the top (4)
Old Nov 12, 2006 | 02:02 PM
Glex25's Avatar
Administrator
have a flat head screwdriver for the 2 corners you will have to pass it through the grille fins and twist a plastic clip to loosen your grill.
People always forget about those
Old Nov 12, 2006 | 03:10 PM
Calvin's Avatar
Overglorified Altima
theres four clips on the top. remove those with a flathead. then there are 2 square clips (1 on each side) which look like <->. you need to turn the 2 square clips so they look like [\]. these clips are in the upper corners of each side. itll be obvious when you see them. again, use a flathead for this.
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Frostbite91
Jul 27, 2015 05:25 AM
