Little light for analog clock
Old Jan 3, 2007 | 09:06 PM
avengence's Avatar
I am wondering why the little lights in my analog clock burned up. I took it out when I did the install for my PA11-NIS and since then it hasnt lit up. The clock works fine though. Could I have broken the filiments on them from moving it? Where can I get these lights... does autozone or something carry them?
Old Jan 3, 2007 | 09:45 PM
jinubob81's Avatar
Evil Bastard
if you're gonna be in there, throw in some leds or something. of course, you'll have to wait longer, but now would be the time to make little mods here and there assuming you want a different look.
Old Jan 3, 2007 | 10:23 PM
avengence's Avatar
Can you buy new lights for in there? I am not even sure what those are called lol.
Old Jan 3, 2007 | 10:59 PM
TheTrance's Avatar
for some unknown reason (to me) the bulbs go out when you take the front out to install something. There are 2 bulbs. about $50 bucks (canadian) for both at the dealer
Old Jan 3, 2007 | 11:03 PM
cturnbull802's Avatar
one of mine came burned out with my car.. is it hard to put an LED in its place? is a resistor needed?
Old Jan 3, 2007 | 11:14 PM
avengence's Avatar
guess i should bust out the multimeter and check the voltages and see what i can do.
Old Jan 3, 2007 | 11:38 PM
silvsurf's Avatar
No ****, I thought I did something when I installed my PAC unit. Same exact thing happened to me. Never re-opened it to check it out. Let us know if you figure out the problem.
Old Jan 3, 2007 | 11:41 PM
avengence's Avatar
I opened it up a little while ago and it looks like the filiment is actually broken.
Old Jan 4, 2007 | 01:19 PM
DocJohn's Avatar
You can get these bulbs from the dealership. The part number for the clock bulbs is: 24860-AM620
See: http://www.infinitihelp.com/Ownershi.../ITB03-065.htm
Of course you can always try to retrofit some LED's in place of these bulbs.
Old Jan 6, 2007 | 01:23 PM
avengence's Avatar
Well I just found out from my dad that they are 10 dollars each so 20 all together from the infiniti dealership and they are even delivering them for me on monday
Old Jan 13, 2007 | 05:04 AM
DoteDote's Avatar
This is interesting at least, multiple reports that after removing the clock, the lamps blow. In my case, I installed the Harman Kardon Drive+Play last Summer. Afterwards, the left clock lamp had blown. Tonight, I finished installing the PAC-NIS2 for much improved iPod audio with the D+P and now the right clock lamp has blown.
Therefore, I'll pick up some LEDs at Radio Shack later today. I'm about to open the clock and see what's in there.
Old Jan 13, 2007 | 11:04 AM
M4Gunner's Avatar
look for accordfreak, and pick his brain. i think he could tell you anything you need to know about the dash.
Old Jan 13, 2007 | 11:14 AM
Bryant's Avatar
What model G do you have? Year? If you're still under warranty, the dealership will fix this for you. I had to have my clock lights replaced in June under warranty.
Old Jan 13, 2007 | 12:36 PM
avengence's Avatar
I already got new ones. It was no big deal, I got 12 dollars off of them ended up being 18 dollars for both.
Old Jan 13, 2007 | 12:40 PM
Hi-TechG35's Avatar
+1 AccordFreak is the man when it comes to light projects.
