Diy Side Skirt Removal
Old Jan 25, 2007 | 12:47 PM
balla's Avatar
can someone please do a real quick DIY on how to remove the OEM side skirt and if you want to even go beyond a DIY on how to install the Greddy Sides. i have work so when i come back i wanted to install them but if i don't do it today then i wont be able to install them for a whole week!! and im not patient!!! hahaha. if anyone can help i would really appreciate it! thanks so much.
Old Jan 25, 2007 | 07:00 PM
jjyellow's Avatar
There are about 7 10mm bolts at the bottom of the side skirt under the car. remove those. There are 2 screws at each end in the fender wall. after all bolts and scres take out, pull out b/c have clips holding side skirt on also. Holpe this helps
Old Mar 11, 2007 | 06:59 PM
Gam3's Avatar
ill be upgrading to 06 sport skirts in the summer...is it a DIY job?
Old Mar 11, 2007 | 07:10 PM
Calvin's Avatar
Overglorified Altima
yep
Old Mar 12, 2007 | 01:41 PM
G-MENTED's Avatar
easy stuff.
hey jjyellow, thats a cute dog you got in your avatar. kinda F'ed up putting him between two hot dog buns though.
Old Jun 10, 2007 | 03:14 AM
O HELLA JDM's Avatar
uhmm bump for this...can someone do it with pictures
Old Jun 22, 2007 | 01:20 AM
PhxBlue's Avatar
Polyester Pileup FTW!
I had to fix a side skirt today and it was pretty easy. It has the seven screws underneath. The screw closest to the front wheel on the underside of the skirt is hidden under the splash guard if you have them. Once you have all 9 screws removed I would suggest starting at one end and use gentle force to pull straight out towards yourself until the plastic clip pops out and continue working on down the side skirt. OH btw have your door open when you do this too.
Old Jun 22, 2007 | 03:07 PM
EricIsKlumzyee's Avatar
open your door..
take off all the screws on the bottom and sides and rip the thing off
- Eric
Old Jun 22, 2007 | 04:35 PM
Originally Posted by Klumzyee
open your door..
- Eric
hahaha cant rip it off if your trying to sell it
erickLA
Aug 20, 2015 09:53 PM
linedr89
Aug 17, 2015 05:11 PM
yoyoyo8
Aug 12, 2015 03:04 AM
st33zygill
Jul 29, 2015 10:05 PM
Kz_Ed
Jul 23, 2015 02:41 AM
