Gauges Installation
Old Feb 11, 2007 | 12:05 PM
gregthay's Avatar
Gauges Installation
Hi,
I have recently bought four gauges for my G35/350GT and have plans to install them above the centre console clock/climate control area and was wondering where the best routes through to the engine bay would be for the wiring (to the battery and to the engine itself)? Has anyone installed any aftermarket gauges in a similar way at all? Are there any DIY guides on installing any gauges to G35's at all?
Also, if anyone can point me in the direction of where to fit the oil pressure, oil and water temperature sensors, it would help as my instructions that came with the gauges are as useful as a faulty sat nav system!
Any help appreciated.
Greg
Old Feb 16, 2007 | 10:52 PM
Boostedef's Avatar
if the guages have their own sensors I would make a t-fitting where the stock sensor is. Thats what Ive done on other cars
Old Feb 16, 2007 | 10:57 PM
Down_Shift's Avatar
You need to let us know what gauges you are trying to install so we know where to tap...
You can run things under the glove box.. there's a hole through the firewall. Leads to the battery area
Old Feb 21, 2007 | 07:54 AM
gregthay's Avatar
Hi,
Tyring to install an oil pressure gauge, an oil temperature gauge and a water temperature gauge. Have found the hole through to the battery area, just need to know where the sensors need to attach / go to. Where do you measure the temperature of the oil??
Thanks in advance,
Greg
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
jcardodeucedos
Aug 27, 2015 06:28 PM
TWASkyliner
Aug 1, 2015 11:43 AM
