HELP! Looking for a Strong Adhesive
Old Feb 25, 2007 | 09:15 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
I bought some carbon fiber overlays for the battery covers to match my carbon fiber Z-Tube. The adhesive on the back of these did not hold up and this is after I cleaned the covers with dish detergent, alcohol and then used the adhesive promoter. After about a month the overlays started to peal off. I'm not sure if this is because of cold or heat or just poor adhesive backing. Anyway, I am looking for an adhesive that will hold these overlays in place for good. I was thinking marine epoxy, but that is kind of messy to work with. Does anyone have any ideas or has used anything that really worked. I need some help as these things were not cheap and I don't want to just toss them out. I appreciate all opinions. Thanks.
Old Feb 25, 2007 | 07:30 PM
DrewTheSuit's Avatar
you can try liquid nails or JB weld
Old Feb 26, 2007 | 10:23 PM
savefatkids's Avatar
just use 3m spray glue, that should work
Old Feb 26, 2007 | 11:46 PM
k67p67's Avatar
I would try contact cement. Both surfaces are flat. Shouldn't be a problem.
Old Feb 27, 2007 | 01:03 AM
Bigd2k6's Avatar
definitely that JB weld stuff that comes in two seperate syringes (sp?). it should hold up to the heat for quite a while but be quick about it if you're applying it around heat because it will set with the quickness.
Old Feb 27, 2007 | 10:15 AM
tkman00's Avatar
i scuffed up my covers w/ some 600 grit sandpaper and cleaned them w/ soap. then i used crazy glue. i've tried the mixed plastic epoxy and that wasn't worth the trouble.
Old Feb 27, 2007 | 09:47 PM
DHCrocks's Avatar
gorilla glue is pretty strong, use a sponge to dampen the back of the piece to be glued, moisture cures the product. becareful applying it, it foams up while it cures. you should try practiceing with it first to get the hang of it.
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Derekb
Sep 21, 2015 05:29 PM
