Looking for DIY instruction for side skirt
Old Mar 1, 2007 | 01:47 AM
G-Ride Canada's Avatar
Hey guys, I thought I saw a thread that shows how to uninstall side skirt the other day, but I can't seem to find it any more. can someone help me out please? thanks!
Old Mar 1, 2007 | 01:51 AM
Calvin's Avatar
Overglorified Altima
Originally Posted by jjyellow
There are about 7 10mm bolts at the bottom of the side skirt under the car. remove those. There are 2 screws at each end in the fender wall. after all bolts and scres take out, pull out b/c have clips holding side skirt on also. Holpe this helps
Old Mar 1, 2007 | 01:57 AM
!! thanks! I was hoping you would be the first to hlep me out!! haha, ahero to the rescue! thanks for the fast reply
Old Mar 1, 2007 | 08:04 AM
Glex25's Avatar
Administrator
There should actually be a thread on how each aftermarket sideskirt gets mounted since I know some if not all do not mount the same way as the OEM
Old Mar 1, 2007 | 12:16 PM
well I have greddy side skirt that i can't wait to put on, but according to ahero, i can see the wholes for the screws under the skirts and screw holes at the end of each side, as well as the holes for the clips.....
Old Jun 22, 2007 | 01:19 AM
PhxBlue's Avatar
Polyester Pileup FTW!
I had to fix a side skirt today and it was pretty easy. It has the seven screws underneath. The screw closest to the front wheel on the underside of the skirt is hidden under the splash guard if you have them. Once you have all 9 screws removed I would suggest starting at one end and use gentle force to pull straight out towards yourself until the plastic clip pops out and continue working on down the side skirt. OH btw have your door open when you do this too.
Old Aug 10, 2007 | 06:45 PM
I finally decided to put my sideskirt on today, but the driver side has a lil gap, kinda hanging down, what clips or screws can I use for the connector on the door panel?
I dont have any idea how to hold it up tight
Old Aug 10, 2007 | 09:18 PM
someone help pls!
erickLA
Aug 20, 2015 09:53 PM
linedr89
Aug 17, 2015 05:11 PM
yoyoyo8
Aug 12, 2015 03:04 AM
Kz_Ed
Jul 23, 2015 02:41 AM
