What kind of spray paint to paint grille?
Old Mar 25, 2007 | 06:38 PM
jackygor's Avatar
I am just wondering as I have decided to do it myself.
What kind of primer to use? for plastic or for metal?
What kind of paint to use? for plastic or for metal?
I am asking since the grille is chromed, i don't know if it is metal or plastic
Oh ya, I want to paint the back emblems black too, anyone experienced chipping if you spray paint it?
thanks!
Old Mar 25, 2007 | 06:42 PM
Triji's Avatar
Heck, Pep Boys would have everything you need... I would get a adhesion promoter, Either Krylon, or Dupli Color primer and paints... I prefere Krylon to Dupli Color personally though...
Also get some clear coat for extra protection against chipping... 3 coats of clear is all you really need but I go with 6-8 coats of clear for greater depth and more protection.
GL
Old Mar 25, 2007 | 06:44 PM
savefatkids's Avatar
not sure about the front grill but for the rear emblems all i did was primer and paint..didnt sand it or anythig and it came out lookng good and never chiped snice its in the back of the car
Old Mar 25, 2007 | 06:52 PM
20004DSC's Avatar
The grill is plastic, I painted mine with spray primer and Rustoleum black pearl and then sprayed some high temp spray clear over that. The only reason why I used high temp clear is that I have seen some regular clears turn yellow just from the heat of sunlight. You will want to take the emblem of the grill and paint it seperate. I didn't the first time I painted mine and it started to chip around the edges. I do have to repaint mine about every 6 months or so due to stone chips but it is very easy. Hope this helps.
Brian
Attached Thumbnails What kind of spray paint to paint grille?-g35-00004.jpg   What kind of spray paint to paint grille?-g35-00005.jpg
Old Mar 25, 2007 | 07:00 PM
IvoryGT's Avatar
you will need UV resistant clear coat. It's not the heat that turns it yellow.
Old Mar 25, 2007 | 07:36 PM
BadBoy06's Avatar
^^^^very true..UV FTW
Old Mar 25, 2007 | 07:49 PM
Triji's Avatar
Check this site out for great paints and great tips for a seamless job!!
http://www.paintscratch.com/
Old Mar 25, 2007 | 08:00 PM
gary c's Avatar
Painted grille.............?
I guess that would be the easy way to change the color of your grille but
in six months time you'll have it out redoing the job again. I've painted
grilles on several of my cars, and it looks great after you finish. But the
best way to accomplish this task is to have it powder coated because the
grille is subjected to constant pitting from sand and rocks.
Old Mar 25, 2007 | 09:13 PM
jackygor's Avatar
w00t! thanks for the fast replies!
Old Mar 25, 2007 | 09:46 PM
DrewTheSuit's Avatar
you cannot powdercoat plastic^^^
Old Mar 25, 2007 | 09:58 PM
y does everyone think u can powdercoat a grill.. powdercoating involves sticking the grill in the oven..if u put a PLASTIC gril in the oven.. its not gona be a grill when it comes out
Old Mar 26, 2007 | 08:34 PM
GreenGoblin's Avatar
The goblin resurrection
lol I dont know why people think that
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
alessandro
Oct 8, 2015 09:29 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
dorkstar
Steering & Suspension
Sep 16, 2015 01:02 AM
