Fender Paint Crack
Old Apr 17, 2007 | 05:30 PM
heyitzalex's Avatar
Fender Paint Crack
so i noticed on my car that the paint has cracked on both fenders at the exact same location. i just recently dropped it on tein basics, but i am pretty sure that this is not the case. there is no rubbing in the front, everything is fine. anybody know what maybe causing this?
sorry gdupsedan for using your pic
Old Apr 17, 2007 | 05:32 PM
filanj's Avatar
Take it to the dealer and talk to them about it.
Old Apr 17, 2007 | 05:37 PM
GThIrtYFiZle's Avatar
Th dealer will probable say you did something while dropping it.
Old Apr 17, 2007 | 05:38 PM
Nismo G's Avatar
My paint is starting to peal on the front bumper at the same location if you moved clockwise to 3 oclock from where your arrow is my paint is pealing right there...
-Sean
Old Apr 17, 2007 | 05:39 PM
izmir41500's Avatar
G35driver Addict
are you sure you're not rubbing while taking hard turns? feel the fender and see if it is bent upwards.
Old Apr 17, 2007 | 06:35 PM
heyitzalex's Avatar
just checked rubbing caused it, damn 20s
Old Apr 17, 2007 | 06:38 PM
izmir41500's Avatar
G35driver Addict
yea, figured. now the million dollar question: how you gonna fix it?
Old Apr 17, 2007 | 06:42 PM
jclit's Avatar
Yup its the rims, myn is cracked in the same exact location.
Old Apr 17, 2007 | 06:45 PM
(>")> G35's Avatar
What's up with the 20"s? I've seen you running around ucla lately with what looks to be 350z track wheels. I sitll can't make my mind on that m spoiler, it looks good...but still need to think about. Wish I knew what was causing the cracking, did you roll your fenders? It may be begining to give, if you rolled them.
Old Apr 17, 2007 | 06:53 PM
Front fenders on the coupe already come rolled.
Old Apr 17, 2007 | 07:40 PM
Calvin's Avatar
Overglorified Altima
on the sedan as well. that doesnt mean you cant still rub.
Old Apr 19, 2007 | 12:35 PM
heyitzalex's Avatar
I had some 17in oem wheels on for a while. i just put the jlines back on. im most likely going to dial in some more neg camber in the front. the front fenders are already rolled from factory, but maybe ill need to roll them even more.
Old Apr 19, 2007 | 12:48 PM
superdds's Avatar
when i had my rear fenders rolled, i experienced paint chipping and cracking. i ended up having a reputable body shop sand down the affected area, repaint, and re-clearcoat quarterpanels on both sides. before doing so, he rolled the fender back even more so i now i probably can run 295s! still it was almost a grand to do the repairs.
Old Apr 19, 2007 | 04:29 PM
G35MR2's Avatar
-Sean
Have the same problem dude, from my Greddy scraping.
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
TeamNoSleep
Sep 13, 2015 07:40 PM
