i had the day off so i decided to do something special for my significant other...i need to touch-up a couple spots before i put it back on, but everyone likes pics
what kinda prep work was involved? did you sand/primer/paint/clear it or did you just spray it with a black paint?
dry sanded w/ 220 grit...then used high heat flat black which was recommended not to use with a primer...wetsanded w/ 500 grit then another coat of black...repeated 1 more time, then it was sprayed with clear...i got a little over zealous on one of the coats of clear...so i'm letting it dry tonight, and will probably be lightly sanded and clearcoated once more
Team Transport Member
awe how pretty i miss my stock engine bay it used to be sooooooo clean
Looks good man
Looks good man
Quote:
looks good, man!
i was considering a ztube/popcharger combo...or i could put that extra 200 towards TTOriginally Posted by aHero4Eternity
noice. you weren't kidding! not even a ztube!
looks good, man!
