HELPP!! LED Side Marker
Old Jun 13, 2007 | 12:58 PM
jayizratedx's Avatar
ok so i followed the easy and cheap LED side Marker mod that was posted on here and i made my own LED side Marker lights. i followed the instructions exactly except one thing...i have no clue where to get a LED Holder to plug in the wire.
so since i couldnt find one...i decided to just connect the wire directly without the holder.
i made the whole thing and connected the right sidemarker...perfect it looked great and everything was working fine
i connect the left side....my clearance lights, side markers, license plates, and the lights on my radio and AC control all go out.
so i find out that it was a blown fuse behind the battery. replaced the fuse and i redo the wiring on the LED lights to make sure nothing is wrong...i connect them again..and the same thing happens...
someone pleaseeeeeee help me..what is causing the fuse to blow everytime i connect the second LED?? do i relly need the LED holder? do the LED llights require too much power? someone help please i cant think of anything else to try
Old Jun 13, 2007 | 12:59 PM
by the way i tried asking this in the original DIY for the LED lights and no one responded
here is the original thread
https://g35driver.com/forums/showthr...cheap+LED+side
Old Jun 13, 2007 | 03:22 PM
MidnightG35X's Avatar
LED's definitely do not require more power than the stock bulbs. My guess is that whatever wire you are using for power (+12V) is either hitting the ground wire or some bare metal somewhere down by your wheel well causing it to short out and blow the fuse. Make double sure your power and ground wires are as far apart as possible.
Old Jun 13, 2007 | 04:34 PM
thanks ill rewire the left marker and see if theres any diffrence...this sucks cuz im all out of replacement fuses so im gonan have to go get those at the store...
any recommendation on the best way to connect the wire to the socket?
i relly want this dam thing to just work already i spent a few hours just breaking apart the dam clear corners and getting the dam LEDs to fit in there. this mod has been a real pain in the ***
Old Jun 13, 2007 | 04:38 PM
ttrank's Avatar
Grocery getter
+1
Sounds like something is either wired wrong and/or is shorting to ground.
Old Jun 13, 2007 | 07:34 PM
I soldered mine in making sure to leave as little wire exposed as possible. No problems so far. You've only spent a couple hours? I think the the first time I did mine it took close to 10 from start to finish on mine. Mine wasn't the quick and dirty version though
Old Jun 13, 2007 | 07:59 PM
i fixed it!!!
i had to redo the whole thing there was something contacting causing a short circuit
well...it only took me a few hours...id say about 2...and id say it looks pretty good.
ill put up some pics later on since thats the last of the small mods i gotta do.
next up some rims and my tints ...
Old Jun 14, 2007 | 12:21 AM
chanycrazy's Avatar
sorry for bad diy
Actually you guys don't really need LED holder..
connect wires directly would be better idea.So you can secure it from water..
I don't have any problem so far though..
jayizratedx..I wanna see how yours came out..
hope you like it
Old Jun 14, 2007 | 10:39 AM
Glad to hear you got it fixed!
flytim3
Jul 29, 2016 10:17 PM
G35forlife21
Aug 26, 2015 07:34 PM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
