The Title Pretty Much says the Question, Sylvania Website says Use 921, will a 3157 Bulb Work, and is it Pretty Easy
Now the question is, How do I access the bulbs, is there a DIY SOmewhere?
open your trunk, pull off all the clips on the trunk lid cover with a flat head screwdriver. Pull off the cover and the bulbs should be right there in the housings.
-GP-
-GP-
Quote:
-GP-
exactly how i just changed mine todayOriginally Posted by Gdup35sedan
open your trunk, pull off all the clips on the trunk lid cover with a flat head screwdriver. Pull off the cover and the bulbs should be right there in the housings.-GP-
What size bulbs did you guys use, and what colors?
Its originally White bulbs Right when you reverse?
Yes the oem bulbs are white. Don't use red or amber so people still know you are backing out.
Ya I looked at that site:
Back up light
921
I have no clue what part 921 is, people are using 168 Wedge Lights, will those work?
Back up light
921
Quote:
Back up light
921
The 921 is a larger bulb but has the same base as a 168/194. They will work interchangeably but I would assume since it the 921 is larger, it may have a higher wattage and therefore more light.Originally Posted by Raheel
Ya I looked at that site:Back up light
921
