Gas door ?
Old Jun 18, 2007 | 08:52 PM
cooldog45's Avatar
Gas door ?
Got a quick question, pulled up to get gas and the gas door did not want to open. I used the emergency latch to ope it but it's still not working after trying to play around with it. I can not seem to find a fuse for it. Does anyone know if there is a fuse for the gas tank locking mechanism?
thx
Old Jun 18, 2007 | 08:54 PM
Scootch's Avatar
did u open it from inside ur trunk by pull the carpet back a tad and pulled the plastic lock mecinisum, if so i had same promel, i had to leave gas station and felt like a idiot, so i took my car back home and took carpet off that side and pushed the platic locking piece back in snug and it worked fine since
note this happened on my sedna not mu coupe
hopfully it will work agn for you
try changing your door lock fuse, its tied into yout factory door locks if you didnt already know, so when you lock your car your gas door locks and when you unlock all doors the gas door will unlock
Old Jun 19, 2007 | 08:04 AM
cooldog45's Avatar
I tried to put the plactic piece back to it's normal config. but it still will not open when I lock and unlock the doors. I called the dealer and they told me that the gas door does not have a fuse to go with it. It's kind of anoying to have it open the whole time.
Old Jun 19, 2007 | 09:23 AM
Scootch's Avatar
all i did was push the plastic piece all the way back in, like it was in the locked possition and then used the key fob and locked and unlocked the doors a few times and it started to work nicly agn, make sure its lubed, like make sure its not sticky
Old Jun 19, 2007 | 10:23 AM
cooldog45's Avatar
So the actuator on the door was shot so I'm getting a new one.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
