window noise
Old Jul 15, 2007 | 01:22 PM
infiniti06's Avatar
window noise
i have an 06 g35 5At and when im driving over bumps i get a rattle. it sounds like it is coming from the driverside window in the top left hand corner. i have check everything in that conrner and nothing. is it possible for it to be something loose in the door and the sound traveling thru the window. any suggestions would be very helpfull.
thank you
Old Jul 15, 2007 | 02:53 PM
madscientist's Avatar
is it a creak rather than a rattle?
i have this annoying creak that comes from the top corner of my driver's side window whenever i go over a bump. i took it back to the dealer and they tightened some bolts in the regulator or something which fixed it for a day. It's back again and it's driving me crazy!!!
Old Jul 15, 2007 | 03:36 PM
infiniti06's Avatar
yeah it is like a crreking sound and it drives me nuts
Old Jul 15, 2007 | 05:55 PM
Bobyl573's Avatar
yea happens to me too :/ not sure what that is
Old Jul 16, 2007 | 02:28 AM
addision's Avatar
just to let you know it happens in my '04 as well, I have no idea what this is
Old Jul 16, 2007 | 02:42 AM
Otacon132's Avatar
wow i was about to start a thread the other day about this, i have a similar problem - when i hit a bump i get a "CLACK" coming from the door panel area, not sure if its what you guys are talking about, but i can reproduce it by pushing in my door panel
Old Jul 16, 2007 | 12:54 PM
DOCSG35's Avatar
Happens on my '05 g35 as well!
Old Jul 16, 2007 | 04:16 PM
CaptG35's Avatar
Its happening in mine as well. Check the sedan forums. Evidently there was a recall/fix for some actuator bolts in the door. I spoke with a service guy and he said that he thought it was only a sedan problem but would be willing to do it on my coupe if I would like. I just have taken the time to take it up there yet. Might be worth looking into.
Old Jul 16, 2007 | 04:54 PM
joe603's Avatar
Are you sure it's not coming from the seat belt holder rubbing on the seat?
Old Jul 16, 2007 | 05:36 PM
yup
when the window is down (even just a crack) there is no noise.
I'd love to hear about that sedan fix
if it works I'll do it myself.
when the dealership tightened my regulator bolts they didn't tighten the bolt that held the whole door together (at the bottom part of the handle) and now that rattles too. I'm too lazy to bring it back for that. figured I'll fix it myself one of these days.
Old Jul 17, 2007 | 03:28 PM
JTG35's Avatar
Hey I have that proble too... Got to call dealer soon
Old Jul 18, 2007 | 02:56 AM
kenasaki's Avatar
what is the recall? what year is it for?
also, seatbelts have lifetime warranty, right?
Old Jul 18, 2007 | 03:55 AM
negative's Avatar
It thought it was from my driver side window, too. Turns out it was my freakin' bottled water (on the door bottle holder) that was making the noise.
LOL!
Old Jul 18, 2007 | 07:45 AM
DHCrocks's Avatar
check the bolt holding the bottom of the glass to the track. mine was loose in the front drivers side causing a little bit of rattling and the front edge of the window had a slight gap causing wind noise. I tightened up the bolt and it was cured.
Old Jul 18, 2007 | 06:28 PM
can you do a writeup how you did this, i'd love to know before i take my door apart.
Thanks.
