window noise
Old Jul 18, 2007 | 07:59 PM
DHCrocks's Avatar
Originally Posted by madscientist
can you do a writeup how you did this, i'd love to know before i take my door apart.
Thanks.
sorry no pics.
1. remove door panel.
a) remove screw at door open pull.
b) remove door handle trim, pry silver plastic trim piece from lower side
with a screw driver. There's a small notch for the screw driver blade to
fit in. remove the two screws behind this cover.
c) lift window switch plate up from the front edge it just pops off.
unplug wire harness.
d) pull door panel off, clips hold it on, start from the lower edge.
e) remove door lock and handle rods from the levers.
f) unplug courtesy sight at bottom of door.
2. remove inner door skin, this is the metal plate that is held on by a bunch of bolts. This will gain you access to the track bolts. I'm not positive but you may be able to get to them without removing this plate. I have sound deadener apllied to the door so it hides all the holes so I couldn't see it. But I'm pretty sure there are holes covered by tape where the window bolts can be accessed.
3. plug window switch back in and raise/lower the window till you can see the lower track bracket. There is two 10mm bolts holding the window to the track. The bolts look like they are attached to a plastic piece on the lowed edge of the glass. My front bolt was loose and causing the window to rattle and also not close completly flush, so wind noise occured at high speeds. It's a good idea to close the door and check from the outside if the window is in alignment. you might need to loosen the bolt and re position the window a few times before you get it right.
Old Aug 1, 2007 | 06:35 PM
madscientist's Avatar
cool
thanks a lot.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
