Remove Side View Mirror?
Old Aug 17, 2007 | 07:29 PM
KulG35's Avatar
the side view mirror all the way out show too much car for me, anyone know how to remove side view mirror housing?
Thanks for the help!
Old Aug 19, 2007 | 02:53 AM
shipsaeki's Avatar
the whole entire housing?
well, first start by removing the door panel.
To remove the door panel there are 3 screws that need to be removed.
If you pop off the cover for where the handle is, there are 2 10mm bolts. then there is another small plastic cover concealing another 10mm bolt behind the actual handle/lever you open the door with from the inside.
once all 3 screws are removed, tug on the door panel from the bottom. the door panel should come off.
once the door panel is removed, look by where the mirror is located. there is a plastic cover with plastic clips concealing more 10mm bolts to loosen the mirror.
everything from there on is pretty self explanitory.
good luck!
Old Aug 20, 2007 | 12:05 PM
KulG35's Avatar
Thanks! Ya, I want to adjust where the housing sits so I can have the mirrors "resting" further out so I don't see the side of my car when I look in them.
good luck!
Old Aug 20, 2007 | 05:00 PM
EricIsKlumzyee's Avatar
test drive to make sure there arnt any windnoises before putting the door panel back on
mjfenix
Aug 17, 2017 05:49 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
emorehs
Jul 17, 2015 09:45 AM
